Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 77
    Aug 2004
    #21
    currently using this brand for almost 4kms na on our altis.
    performance is almost comparable sa oem ng altis (9th gen).
    #22
    for DD ok siya less dust, pero it tends to fade after some hard braking
    Quote Originally Posted by BLUR-RT View Post
    Yung Metal king and above premium line yung maganda ang brakeing power and does not fade as easily. kaso nga daw, mas malakas kumain ng rotor vs OEM or ordinary replacement. Pero gaano kaya katagal yun actually? Lets say after 20,000 kms eh hindi na OEM at Bendix Metal King na gagamitin for a brand new car ha.
    Apr 2011
    #24
    just installed these pads awhile ago. ok ang braking power niya and nawala ang *chug..chug..chug..chug* sound when braking.
    #25
    Anyone know the distributor of Bendix. I believe the shop/office is located in Paco, Manila
    Quote Originally Posted by edtf View Post
    Sir tignan mo link sa post # 19, andun mga know list of sellers....
    #27
    yah kumakain nga ng rotor pero not that drastic, wala ako figures pero i used metal kings on my daily drive car with occasional track days for 3 years konti lang yung kinain sa rotor
    Salamat sa info. Balak ko kasi ipalit sa susunod ay yung Metal King na. Parang nitin yung General CT e.
    #29
    pansin ko din yan, mas mainit yung mags ko now kaysa nung nka metal kings ako
    Sep 2009
    #30
    i got mine at banawe for 750pesos for a replacement on still OEM pads on my Toyota Revo. So far it doing what's its supposed to do. Ill monitor the performance of it as well
    #31
    After refacing, I used Bendix general for my a/t altis, more than 3 years na...so far so good!
    walang pinagkaiba sa performance compared sa orig toyota parts.
    Quote Originally Posted by admiral88 View Post
    Sa strada 4x4 '95 mdl ko noon ganun din ginawa ko, after refacig I used Bendix General CT, works well.
    Aug 2009
    #33
    I just put a set on the Land Cruiser (~900/set of front pads) and on the Jazz (~700/set of front pads).
    Said to have some sort of Ceramic Technology thingie. Currently both sets are less than a month old. I have no complaints.
    I've tried Bendix Standard pads before on some of the older units and I've had a so-so experience with Rico brake pads (cheap but you get what you pay for) on the Patrol.
    Anyone else have experience with Bendix Generals?
    I got them and had them installed at Glenn's/Ronald's shop in Kamias.
    same combination here for my liteace 96 model. bendix break pads (front) and rico drum break (back)
    Feb 2012
    #34
    have had the general CT on my altis for some two months already. cheap *Php680 - 800 but grips well and is silent. seems gentle on rotors too, judging how easily it was sanded and the amount of shaved material after just a few strokes. initially, brake dusts were observed but after about two weeks have subsided already. bought another set as i changed discs from the stock old, warped rotors to runstop slotted and drilled ones. one thing i learned is when changing to new rotors, better change your pads too at the same time. medyo nagkaproblema yung old/new ones kasi parang sumasabit dun sa slots ng rotor when braking, so have to shave them again (via sanding). kaka-sand lang din nya when i changed rotors. since makapal pa, wag na daw muna palitan. so i paid P200 to have it checked a day after the replacement, and may have to pay again to put in the new pads. (gawin ko na lang reserve yung months old thick pads). decided to go to a new set again for a more even wear sa new rotors and pads. pero balak ko i-DIY na lang sa bahay, para ma-clean and grease na rin brake assembly kasi sa shop talagang kabit lang din. kung sisipagin, baka i-paint ko na rin calipers.
    #35
    The Bendix lasted about a year on the Land Cruiser but the shop said it can be normal for heavy vehicles especially when running larger tires. I will probably try the Metal King as suggested by Dr. G's shop. On the 2010 Montero Sport, we replaced the stock tokico brake pads with Bendix also. Will upload photos later.
    Oct 2005
    #36
    have always been a bendix user
    during my last front pads and rear brake adjustment.
    on my office service car.
    have also used bendix on my Vios. it has overwhelming amounts of dusts but seems to do the job well. ok naman, would recommended it.
    Oct 2011
    #37
    tried and tested na ang bendix brake pads.
    #38
    OEM Tokico Brake Pads of the 2010 Montero Sport:
    Replaced with Bendix General CT Pads (Php950.00 SRP):
    Thinking of getting this one next time around for my Toyota (no price yet). Ok ba ito?
    Naka-try na rin ako niyan doc, mas maganda braking power and lesser talaga brake fade even in extended downhill drive. Definitely an improvement over the general CT.
    Sep 2009
    #40
    Speaking of Bendix pads, pinakabit ko sa Mitsu VV casa yung Bendix pads na nabili ko. Sabi ng SA, peke raw yung Bendix.
    Question is, may peke bang Bendix?
Anyone tried Bendix General CT Pads?
