Results 1 to 10 of 37
- Oct 2005
- 72
April 30th, 2007 09:36 AM #1I'm having a problem with my GLI may ugong mag nililko iyon specially pag mabagal ang takbo ng car. Do you thinks power steering need to replace or repairable b ito ?
please help.
thanks
April 30th, 2007 09:53 AM #2
i also had experienced it before...pag nililiko mo maugong...ncheck mo n b ung ATF nya?un skin kc,akala ko palaging puno ngaun pala may plastic n nlagay,tapos nung nilagyan ko nung fluid...nawala n..hope it helps..
- Oct 2005
- 72
April 30th, 2007 11:44 AM #3Sir alord , actually nacheck ko puno pa iyon fluid na power steering... is there any other possible cause ?
to other tsikoters.... please advise.
thanks
April 30th, 2007 09:56 PM #6
Bigbody ba 'to? Sakit yata talaga ng bigbody 'to, one of the most common complaints na nakita ko is power steering.
Anyway, first thing is to check the fluid. Pag ok ang level, either the pump or hose lang yan. Ang alam ko maselan ang power steering ng Toyota. May nakapagsabi sa'kin na kailangan eksakto yung sukat ng replacement hose sa original, kundi meron pa ring konting tunog pag nililiko.
hth
- Oct 2005
- 72
May 2nd, 2007 07:38 AM #7The_NOISE ...>>> yeah big body GLI ... iyung ugong experience ko once na naka on engine at nakapark at once you move the wheels either left to right . may ugong but kung naktakbo ka na ng mabilis wala siyan ugon na maririnig.
nacheck ko naman ang fluid ok naman.
iyong hose ba available naman ito anywhere sa automotive store ?
madali lang naman ba ito ireplace... ?
pls. advise... thanks in advance...
May 2nd, 2007 05:16 PM #8
same with my 1996 camry pagtinotodo ko yung manibela naugong..as per my mechanic nung chek nya yung car humihinto yung pump pagnakatodo and i think yun yung reason y naugong..is it normal o ano kailangan ko gawin? thanks..also wat are the other factor why malakas sa gas..ok nman yung makina..many thanks..
May 2nd, 2007 06:13 PM #9
May 3rd, 2007 10:01 AM #10
thanks bro..ill check that..anyone here my idea pa just tell me..many thanks..
[QUOTE=ice15;3387274]medyo disappointing itong Sealion 5 No front sensor either Manual Seats...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
