Results 21 to 30 of 37
May 15th, 2007 04:19 PM #21
3500 po + labor = 4,500 petot
pinagawa ko kasi ke speedyfix eh, so far ok naman.
- Nov 2006
- 299
May 15th, 2007 06:19 PM #22pwedeng greet muna ako,thanks.
=====hi guys musta na kayo,miss ko na kayo,i just came back off from bakasyon with my wife,,..
anyway regarding sa probs ni mike,mayroon lang hangin na nakapasok sa steering system ng car mo and kadalasan yan ay natrap sa hose,kung hindi converted ang kotse mo ay mas malakas ang ugong nyan pag left turn at 5-10 km/h 1500rpm.kailangan na talaga na palitan ang hose nyan.i hope it will help you out......once again hi to everybody.
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Oct 2005
- 72
May 16th, 2007 11:57 AM #24Yoda > ask ko lang sir,,,, iyong power steering hose na pinalitan mo purely hose , wala b siyang naka crimp sa both side at may hallow tube na assy. ?
thanks in advance
DIY to death!
- Jan 2003
- 451
May 16th, 2007 02:52 PM #25
May 16th, 2007 11:16 PM #26
sir speedy hehehe :D meron pa rin konti sabi kasi ni renan
since replacement hose lang un, ndi talaga matatanggal ng
yung ugong, pero konti nawala sa ingay.
ang habol ko kasi yung lambot eh, so ngayon ok na ok yun
ikot ko kahit me ugong ng konti hehehe pero tolerable naman po.
next stop ko yung tbelt ko :D punta na lang ulet ako kapag me time na :D
- Jul 2006
- 145
November 29th, 2007 12:02 AM #27mga co GLI users, i am suffering for that ugong. It started when i had problem sa left turn, sobrang bigat.Then my mechanic told me that the issue is 90% at the gear box kc daw kung pump kaliwat kanan ang maganit.Then he overhauled the rackendpinion and pinaltan ng repair kit.In short my problem was solved at lumambot na yung steering ko, but this UGONG occured. Then sunod kong pinabaklas ay ung pump,BUT ANDUN PA RIN YUNG UGONG. Ang tanong ko po, especially kay speedy fix, pwede bang balewalain ko n lang yung UGONG, kc ok naman ang steering , malambot naman eh...dedmahin ko na lang ba to? Di ba delikado? Nalalakihan na ko ng gastos buti na lang naka discount ako sa pag overhaul ng pump.
Please advise po mga experts..maraming salamt
December 1st, 2007 08:28 AM #28
sa akin din. di nawala yun ugong kahit nagpalit na ako power steering hose. tapos may tagas akong konti, decided to use the Cyclo's stop leak power steering fluid. nawala yun tagas, tapos gumaan yun manibela ko and nawala ugong. May konting ugong lang kapag nakatodo liko at di umaandar.
December 1st, 2007 11:09 PM #29
dati may ugong din yung lovelife ko, ang ginawa ko nagpalit ako ng hose sa panorama sa may taft, 1800 + 300 labor sa trusted mechanic ko, pagkakbit, may ugong parin lalo na kapag cold start, so ang ginawa ko bnleed ko pero dapat pagnagbbleed ka walang takip muna yung sa lalagyan ng power steering fluid kasi dun lalaba yung extra na hangin na cause ng ugong.. after doing so, nawala na yung ugong.. hope this helps.
December 2nd, 2007 05:32 PM #30
saken nagpapalit ako ng fluid. dati kasi ATF ang gamit sa steering ko.
then nung nabasa ko ibang inputs ng mga gurus dito na kung ano daw
ang dapat sa steering fluid tinry ko yung power steering fluid talaga.
ayun nawala ugong ng auto ko at gumaan pa yung manibela ko
Latest mileage:
