I'm having a problem with my GLI may ugong mag nililko iyon specially pag mabagal ang takbo ng car. Do you thinks power steering need to replace or repairable b ito ?
please help.
thanks
please help.
thanks
i also had experienced it before...pag nililiko mo maugong...ncheck mo n b ung ATF nya?un skin kc,akala ko palaging puno ngaun pala may plastic n nlagay,tapos nung nilagyan ko nung fluid...nawala n..hope it helps..![]()
Sir alord , actually nacheck ko puno pa iyon fluid na power steering... is there any other possible cause ?
to other tsikoters.... please advise.
thanks
Bigbody ba 'to? Sakit yata talaga ng bigbody 'to, one of the most common complaints na nakita ko is power steering.
Anyway, first thing is to check the fluid. Pag ok ang level, either the pump or hose lang yan. Ang alam ko maselan ang power steering ng Toyota. May nakapagsabi sa'kin na kailangan eksakto yung sukat ng replacement hose sa original, kundi meron pa ring konting tunog pag nililiko.
hth
pwedeng greet muna ako,thanks.
=====hi guys musta na kayo,miss ko na kayo,i just came back off from bakasyon with my wife,,..
anyway regarding sa probs ni mike,mayroon lang hangin na nakapasok sa steering system ng car mo and kadalasan yan ay natrap sa hose,kung hindi converted ang kotse mo ay mas malakas ang ugong nyan pag left turn at 5-10 km/h 1500rpm.kailangan na talaga na palitan ang hose nyan.i hope it will help you out......once again hi to everybody.
