Results 1 to 6 of 6
    Apr 2009
    Just noticed that my abs indicator light is on may i know whats the first thing to do with this? Ano kelangan ipa check? Mahal ba ang parts and labor? Prior to this problem ive been hearing squeaking sound during hard breaks on my rear tires. Car is corolla 1997 gli 1.6
    Feb 2009
    Quote Originally Posted by bail View Post
    there could be ferrous dust from your squeaking brakes that is sticking to the rear wheel speed sensor making the signal waveform different from the normal sine waveform.
    try cleaning the sensor tip first
    Meron pala abs ang mga circa 97. Hehehe
    Jan 2009
    Best if the error codes(s) can be read so you'll know exactly what's causing it. Can't help you with the 'how', though.
    Most definitely. The '95 Sentra Series III already had it. I remembered it because it ran TV ads about the feature.
    If you can safely do a low speed emergency stop to activate the ABS, see if it still engages?
    One of the first local cars to have ABS was the 1993 B13 Sentra (SE Saloon).
    search mo sa google how to check abs ng corolla mo. carefull ka lang sa pag sundot ng diagnostic socket ensure na tamang pin masundot mo
ABS light indicator is on what to do?
