Results 51 to 60 of 103
April 4th, 2025 12:14 PM #51
April 4th, 2025 12:21 PM #52
Yes. Ako rin personally worried once na puro hybrid o ev na ang mag-takeover sa market. Complicated silang ayusin once madale sa baha. Unlike kung ICE may pag-asa pa kahit papano.
As for toyota, totoo naman yan. Pero mas ramdam talaga if gamitin sila as daily workhorse vehicle. Although yung iba mas prefer ibang brand kasi feel nila usually mas may character or dating, lalo kung seldom lang pinaaandar at nilalabas.
April 4th, 2025 12:22 PM #53
Lumabas na Error Code:
C0215 Rear Speed Sensor LH Circuit
Galing talaga ng mga tsikoteers, tama yung suspect na ABS sensorLast edited by _Cathy_; April 4th, 2025 at 12:35 PM.
April 4th, 2025 02:08 PM #54
WTF. Bakit ang pinapa palitan ng speedy fix Wheel hub bearing rear left and it costs P22k! labor P1800.
So I spoke to the owner of Speedyfix and he is such a nice guy! He said don't replace na because P25k is almost 1/4 the price of the car hahaha! He said it's just the sensor lang naman. Never pa daw nila nagawa magpalit ng sensor lang, buo ang gawa nila. Although I feel OC na may nakailawLast edited by _Cathy_; April 4th, 2025 at 02:33 PM.
April 4th, 2025 02:40 PM #55
April 4th, 2025 02:51 PM #56
April 4th, 2025 03:00 PM #57
April 4th, 2025 03:18 PM #58
- Oct 2006
- 6,282
April 4th, 2025 03:53 PM #59Its is practical from an economic POV. You could just put a black tape over the light or have someone remove the ABS light bulb/LED. Car is still perfectly usable even withe ABS not working. Hindi ka naman aggressive yata magpatakbo.
Not sure why they want to replace the entire hub, when its just the sensor. If you lok at it the hub has teeth, the sensor then counts how many times a second passes it and from there gives you the car's speed (kaya nga connected siya sa speedometer). If it detects say a sudden negative change in speed e.g. 100kph then biglang naging zero kph (indicating a lockup of the brakes) it will send a signal to the ABS pumps to disengage/re-engage the brakes (simulating the old-school method of pumping the brake pedals). You'll just have to wait till you hear a hum when the wheel turns to know when its time to replace the hub.
April 4th, 2025 04:36 PM #60
i confess, my seagull review is from internet literature. that so-called aircon issue is a...
BYD Seagull
