Results 1 to 9 of 9
    Jul 2012
    Hi Guys,
    May time na naka-on ang ABS and Handbreak pero kapag nagpatay ako ng makina then on ulit, nawawala na.
    Minsan buong biyahe wala, minsan meron.
    Any take?
    Thanks mga master.
    Feb 2012
    Anong car po yan? Ganyan din dati aveo ko then brought to mechanic they scan lumitaw na faulty ung sensor ko sa right rear tire then i replaced both na po. That cost me 180$.
    Sent from my SM-N910G using Tsikot Forums mobile app
    Apr 2006
    check brake fluid reservoir.
    sa akin twice na nangyari. handbrake light was on kahit hindi naman naka-handbrake. open the reservoir cap (nasa above minimum pa naman) tapos galawin mo lang yung sensor.
    Jul 2012
    toyoto altis 2002 po oto ko, sa reservoir sir, lagpas ng kunti sya sa max, balak ko nga bawasan di ko nga alam bakit lagpas sa max yun ngayon.
    sensor sir? can you explain sir?
    thanks
    Jan 2009
    The ABS light could be on for any number of things. The best way to proceed when the light turns on again is to drive to a shop that can read the Diagnostic Trouble Code (DTC), then proceed with the prescribed troubleshooting steps from there.
    Jul 2012
    Yes sir, mas okay nga yan, kaso ang problema ko kapag pinatay na ang oto, then buksan ulit nawawala and di ko alam when siya lalabas or in what instance. Kung sanang lage naka-on pero hindi.
    ang weird.
    Feb 2012
    Quote Originally Posted by anakngsultan View Post
    thanks
    Sensor po baka faulty na, its usual na wear and tear ng mga sasakyan pero iba abot ng ilang taon di nasisira. Pa scan nyu na po then u can see. Ganyan na ganyan kasi nangyari sa akin maybe yan din ang reason. Mag on ung abs light then after a while mawawala naman. Pwedi din abs pump ayun ang mahal. Hehe pero mahirap manghula malaman mulang pag napa scan muna..
    Jul 2012
    Thanks sir, baka mayroong pang SCAN jan na pede mahiram. haha. hirap kasi hindi siya lage naka-on, may time lang.
ABS and Hand brake turn ON
