Results 1 to 9 of 9
- Jul 2003
- 17
May 19th, 2009 11:42 PM #1Baka po may makatulong
Meron po kami 2004 Pajero 3.2 DID local version. Habang gamit ng brother ko, bigla na lang umilaw yung ABS indicator,brake warning light,traction control warning light,traction control off indicator light,tapos biglang humina yung preno sabay tumigas yung pedal feel, tapos may malakas na warning BUZZER sound coming from the center panel
Dinala na po namin sa Mitsubishi Caloocan. Kelangan daw palitan yung ABS module assembly at Hydraulic brake booster assembly which would cost around P160,000 nakupu!!!
May 28th, 2009 04:50 AM #2
Mag second opinion ka dyan...makakabili kana ng gen1 pajero sa halaga na yan hehehehe.
THE AUTO SPECIALIST
- Mar 2006
- 607
May 28th, 2009 10:22 AM #3pwede mo naman ipa -convert sa conventional braking system yan kailangan lang ng conversion fittings .im not sure kung gusto mo yung idea , pero it saves you alot of money .
June 13th, 2009 09:55 PM #4
bka po skaling maka2long sainyo yung parts q.. na auto braking system (ABS RING) sa cv joint mu... ang part po kc ng abs sa constant velocity joint ma support nya yung preno pra mabalance nya yung brake sa kaliwa at sa kanan..pra sa ganon maiwasan po ang out of control...either bka sira nga poh yung sensor ng abs mu..
June 15th, 2009 12:12 PM #5
either pagawa mo sa casa or surplus ang hanapin mo. If you can afford to buy that SUV, replacing parts wouldn't be a problem. Anyway, happy parts hunting!
- Jul 2003
- 17
July 18th, 2009 03:51 PM #6Update.....
Naayos na!!!
Umabot ng P108,000.00 Bill namin
eto yung sira
HBB tawag nila (hydraulic brake booster)
Nag parating pa ng brand new from japan
- Apr 2010
- 1
August 11th, 2010 09:27 PM #7I'm new here. I have a japan pajero shogun and have same problem with my brakes. Computer diagnosed and showing bad HBB. May I know how did you get the HBB assembly and who replaced it? Pls tex me or email: 09198391605 or e_baniqued*yahoo.com. Thank you.
- Mar 2012
- 1
March 3rd, 2012 12:55 AM #8pare favor lang saan ka nakabili, I needed this also pareho tayo ng sira ng sasakyan...please lang thank you
- Jun 2006
- 1,139
March 15th, 2012 12:08 AM #9dapat every 2 years flush ang brake fluid, nagkakatubig at/nagdudumi ang fluid. sisirain non ang seals at abs system.
high idle RPM at engine start
