Results 3,171 to 3,180 of 3407
- May 2018
- 157
March 24th, 2019 04:00 AM #3171Haha.. noted on the Absolut Vodka Sir Travajante..[emoji1]
Thanks po sa reply sir.. worried lang talaga ako lalo na't first time to own.. I read na it will cause rust and corrosion.
I am thinking pa naman of going to MI on monday for a coolant flush. [emoji28]
March 24th, 2019 04:10 AM #3172
- May 2018
- 157
March 24th, 2019 06:21 PM #3173
March 24th, 2019 06:30 PM #3174
March 25th, 2019 12:22 PM #3175
Be careful, use ONLY Subaru Long Life Coolant ... There are alternatives but you have to be well informed about different types of coolants and their composition ... Incompatible coolant type MIGHT damage some metals in the engine ...
- Dec 2014
- 124
April 4th, 2019 03:33 PM #3176is there any way na mapapalit ang suspension ng forester with a suspension ng mga fortuner, montero type?
April 4th, 2019 04:20 PM #3177
The Forester is built on a unibody frame like a car unlike those PPVs which are built on a ladder frame like a pickup. The suspension setup is different between them.
You can stiffen or raise the suspension of a Forester with the proper use of springs and shocks or coilovers. Besides, why would you make the Forester ride like a PPV? One of the great advantages of CUVs is how it drives compared to pickup-platform vehicles and how its suspension is tuned makes that difference.
- Dec 2014
- 124
April 5th, 2019 10:32 AM #3178
April 5th, 2019 11:01 AM #3179
The Forester has good ground clearance, as good as most PPVs. If you want to make the Forester be much better off-road, then you can upgrade the shocks and springs, lift the body a bit, and change to off-road tires.
It will still handle better on twists and turns compared to those ladder frame vehicles.
- Dec 2014
- 124
April 5th, 2019 11:39 AM #3180
No, but it was what sounded closest to Bill, bill. Ha ha ha!
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
