Results 1 to 6 of 6
- Sep 2003
- 14
August 20th, 2015 09:14 AM #1hi guys!!!
i have a wrx 2011 sti, pag start ko makina at properly warmed up na, turn on my aircon
and the compressor would start then after 2 secs, shut off sya uli, the A/C orange light in
the panel is on but the compressor is not working.
pag irekta ang clutch to the battery, iikot ang compressor and lalamig ang aircon, it means there is a wiring/module problem
somewhere. anybody can help whats the fix? am in pampanga.
regards
August 20th, 2015 11:22 AM #2
since you have initially diagnosed it, check the relays, the wirings and the fuse.
since you are at it, check na din status of the aux fan and the freon level.
August 20th, 2015 01:09 PM #3
Same tayo ng problem but yun unit ko ay civic esi. The culprit was the blower switch sa climate control, loose contact. But have your system checked first to isolate things.
- Sep 2003
- 14
August 20th, 2015 02:43 PM #4thank 1d4lv, i have check all of those, all ok.
ok i hope we have the same prob, il try to take apart the panel and check. thanks!
August 21st, 2015 06:51 AM #5
Normally the a/c request switch is greenish or yellow. If the light is somewhat orangey, check or replace the cabin filter
- Mar 2009
- 6
January 29th, 2016 01:39 PM #6Have the same problem with my 07 XT.. A/C is on with blower and does well while moving at regular speed but when you're in a traffic slowly moving or at park and still have the A/C on, it totally doesn't cool at all and you just have the blower acting like a fan.. Maybe someone can help. Thanks!
high idle RPM at engine start
