Page 72 of 72 FirstFirst ... 22626869707172
Results 1,421 to 1,440 of 1440
    Oct 2009
    #1421
    BIYUTIPUL... Doc!
    Apr 2009
    #1422
    Doc wala bang full body shot diyan? lumobo ng husto yung gulong mo.... ganda! parang na pa gym bigla yung gulong lumabas talaga yung tindig... hehehehehe sa luwa ng goma mo get ready to wash your pick up every time na uulan. for sure pag baba mo ng pick up mo the feeling will be mutual pag kita mo sa gilid niya... hehehe...
    Apr 2009
    #1423
    Quote Originally Posted by Arvin Cristi View Post
    doc, may naisip lang ako ngayun, when you removed your old filter did you take out the entire air box? or did you loosen any of the hose clamps for the air hose? also is your air box cover closed properly? sealed shut when you lock it down?
    Boss Arvin,
    Looks like i found the answer...
    Heres my take on my K&N filter. With regards on my previous comments about this filter and after using it for i guess 5 days now, I now have a conclusion.
    I just got home just this morning coming from QC down to Pque. since this was my 1st long drive and since there was little to no traffic i got the chance to really test it. stretched its wheels alil bit. but after i got home I still cant find the difference from the stock filter vs the K&N.
    Maski medyo pagod at antok na ako ng konti sa pag mamaneho hindi parin ako mapakali. kasi parang merong improvement kaso di ko masabi kung asan ba siya o ano ba talaga siya.
    So what i did was i re-installed my old filter so that i can really compare it. I drove around the village. drove it in a casual way and in a heavy footed way.
    after that went home again and replaced it with the K&N. took the same route and same driving habit.
    These are my findings:
    *stock filter- it seems that it has the torque. kasi from 1.8-2k RPM * 2nd-3rd gear ramdam mo mag kick yung turbo pero from 2K rpm to 3K RPM same gears sakto yung increase niya with regards sa speed. di ganoon ka bilis umangat yung RPM. di agad na gagalit yung engine.
    *K&N filter- Found out it has the same torque as the stock filter if not a tad more. the reason i think(psychologically) that it lost some torque was because once you floor it, it quickly reached 3,000RPM from all gears. so galit agad yung makina ( you guys know the sound of your engine once its in 3,000RPM) pero at that point nasa kalagitnaan ka palang ng speed mo for that said gear pero compared sa stock mas mabilis mo din maabot yung speed mo for the given gear.
    say for example:
    -sa stock filter, sa 2nd gear sagad mo 60kph before you shift to 3rd gear.maririning mo na halos galit na yung makina * 50kph.
    -sa K&N at 40-45KPH galit na agad siya kasi nasa 3,000 RPM na agad siya and it can go upto 3.5-4,000 RPM depende nalang talaga sa apak mo. so parang feeling mo ubos na agad yung gears mo pero it will keep on going until ma reach niya yung 60kph which is mas mabilis mo din naman maabot compared sa stock. something like that.
    I am now contented with my K&N drop in filter. the reason bakit ganun yung feel(nagagalit agad yung engine) is because it is less restrictive kaya ang bilis umangat ng RPM giving you more power. reason kung bakit di ko gaano na halata nung una is because halos bago pa yung filter ko at di pa ganoon ka clog but then again even if it was almost new, changing to a K&N filter really makes a difference specially when your overtaking. mas magaang yung takbo niya.
    Is it worth it? For me medyo na impulse buy ako.
    Its worth it kung heavy footed driver ka, ramdam mo talaga specially when over taking no questions asked kuha ka na ng Isa.
    Kung may extra cash ka din why not?
    Not worth it if you drive like only 60-80kph max and your a laid back driver and doesnt use the entire rpm range. since the increase in power is not that much though noticeable.
    Conclusion:
    if your unit is still new i guess wag na muna. pero kung sa susunod na PMS mo eh required na mag palit ng stock filter, i guess this will be a good time to buy the K&N. for sure you will really feel the difference!
    regarding FC, hehehe sa tingin ko sa mga unang lingo lalakas talaga kasi hahataw ka ng hahataw. pero after you get used to it i guess medyo titipid ka pa ng konti.
    Pasensya sa long read. medyo naging novela na. guys this are all just my personal experience.
    thanks and sana naka tulong kahit papaano sa mga gusto mag upgrade ng drop in filter.
    Hehehe Bos Arvin sensya na at mukang na paisip ko kayo sa mga previous post ko.
    time to sleep.
    Jan 2008
    #1424
    Quote Originally Posted by djoverdose View Post
    Boss Arvin,
    say for example:
    Conclusion:
    time to sleep.
    hey doc, no problems there!!!! i'm glad you were able to figure out your problem. enjoy driving!!!
    #1425
    Boss Arvin,
    say for example:
    Conclusion:
    time to sleep.
    Nice observation Sir DJ....if that is the case, sa 20k na ko magpapalit ng filter to k&n.
    Aug 2007
    #1426
    lumobo talaga doc. will post body shot soon
    Apr 2006
    #1427
    sa mga nag upgrade ng tires
    me difference ba ang height and width ng
    265/70/r16 ht/at
    245/70/r16 ht/at
    or the same lang, sa mga nakita ko naka AT/ parang mas malapad tignan kasi kahit same size?
    Thanks
    Apr 2009
    #1428
    Boss Arvin,
    I think sa mga naka Automatic transmission mas ramdam ang difference compared sa manual.
    Apr 2009
    #1429
    saw sir bigblock kanina lang dito sa val area.
    akaka ko kung ano yung itinuturo niya sa bubong ng strada niya.
    gwapo ng roofrack! halos magkaparehas kami hahaha
    ready na ready na siya sa pagudpud funrun!
    Apr 2009
    #1430
    Quote Originally Posted by t3kk3n View Post
    265/70/r16 ht/at
    245/70/r16 ht/at
    or the same lang, sa mga nakita ko naka AT/ parang mas malapad tignan kasi?
    Thanks
    ako naka 245/70 r16 ako sir.... i did increased my pick ups height by 1 inch.
    usually yung stock ng glx na 205/80 r16 has an overall tire diameter of 28.9"
    yung 245/70 r16 is 29.7" (yokohama A/T)
    265/70 r16 is 30.7" (yokohama A/T)
    check mo dito sir http://www.tirerack.com/tires/tires....landar+A%2FT-S
    Apr 2006
    #1431
    *djoverdose
    thanks, im still confuse sa looks ng tires, parang mas malapad tignan ang AT compared sa HT kahit same specs or depende siguro sa brand?
    Sep 2004
    #1432
    Quote Originally Posted by KuL*z View Post
    buy K&n if your about to change your air filter, (i.e. 20k; 40k; 60k KM) unless you have extra cash.
    *djoverdose
    depends also the thread pattern
    Oct 2004
    #1433
    *djoverdose
    A/T tires have longer treads at the shoulders resulting to a square-edged and wider look. But rim width will also matter. 245/70r16 A/T with 16x8 wheels may look beefier than 265/70r16 H/T with 16x7 wheels.
    Mar 2004
    #1434
    sa mga nag upgrade ng tires me difference ba ang height and width ng
    265/70/r16 ht/at
    245/70/r16 ht/at
    Height computation:
    265/70 = 265 mm x 70% = 185.5 mm
    245/70 = 245 mm x 70% = 171.5 mm
    Google for tire size calculator.
    Aug 2007
    #1435
    guys, i have a friend who is looking for a new grill and bash plate baka may mareccomend kayo? thanks
    Aug 2007
    #1436
    body shot
    Jan 2010
    #1437
    Quote Originally Posted by janrye26 View Post
    sir, for grills, you can pm sir dadz. for bash plate, you can pm either bigblock or mdksael.
    Jan 2008
    #1438
    To all drivers/ those bringing their stradas and joining the ilocos trip:
    It would be greatly appreciated if you can furnish me your name, vehicle color and plate number as well as your contact numbers.
    Please indicate as well, where you will be joining the group and how many people will be riding in your vehicle. Also please indicate how many and whom among your passengers is a valid driver.
    I am currently finishing the ride protocol and i will be needing these details for the standard handouts that will be issued to all vehicles joining the trip.
    I will be needing the details at least by thursday night. I hope you all understand.
    Thank you for the support.
    Arvin
    Aug 2007
    #1439
    Quote Originally Posted by jokulit View Post
    thanks. hes looking for this
    Dec 2008
    #1440
    sir sa Thailand ba to or local lang gwapo hhehehe
    MODERATOR'S NOTE:
    This thread is continued at:
    http://tsikot.yehey.com/forums/showthread.php?t=76217
TSCP Strada Mods [continued]
