bro, i got mine from dadz, same on that picture in your post. just pm dadz....
"CALLING DADZ PAKNER" me enquiry dito......![]()
May thread pala dito for mods. Hehe
When you guys upsize your wheels and tires, do you notice any difference in performance/efficiency? Di ko kasi madecide ano gagawin ko sa 2012 glx-v. I've been told that increasing the overall diameter of the tires can screw up a few things.
bro, same here glx pero hindi v, before i used ms sport shoes, 17x60x265. syempre bro mabawasan ng unti yung arangkada nya, di sya kaseng quick dun sa oem tires which 16 lang...smaller total diameter. pero imo, mejo mabilis sya sa hi speed bigger diameter kase yun tires. sa ride "suspension swabe at 30psi parang kotse bro, di mo ramdam ang baku baku na road......but most of all here using 16 x 9 or x 8 x 65 x 275, all terrain will match to your glx since 4x2 lang sya.....opinion lang po yan bro...hope it helps....(today i'm using 20's x 45 x 275...hataw sarap itakbo ng mabilis lapat na lapat sa road at 30psi tire pressure)![]()
Kailan ba EB's niyo?I actually prefer the stock look. Maliit lang talaga. On the way to the office I saw a GLX-V with the stock Montero Sport wheels. Bagay din talaga. Looks much better than the stock GLX. I'm really just concerned with how it will affect the performance and safety of the vehicle.
Thanks. I'm considering getting the rims and tires of the stock MS, or the stock GLS. Unless makahanap ako ng magandang 16 x 8 na rims. If any of you are selling your stock rims, you might have a buyer here![]()
Saan po nakakabili ng rear steel bumper for strada? exact location? thanks![]()
Share ko lang po po (how to improve the sound reproduction of the stock 2010 Strada GLX audio system):
1) Turn off loudness and defeat.
2) Turn on HPF (high pass filter) and set to 100Hz.
3) Set bass center frequency to 200Hz and increase to +3 with 4 width (widest parametric eq setting).
4) Set treble center frequency to 10KHz and increase to +3.
I observed the sound reproduction to have more body and bite with some frequency extension (airness) and crisp even without tweeters (6.5inch dual-cone speakers lang ang stock sa doors). Midbass hits with some RnB and Hiphop tracks are punchy and without distortion even at volume 9.
Meron na po bang naka pag pakabit EGT at Boost Gauge sa Strada nila. Para kasing ok din makita ang boost at temp sa dashboard. Yung kaibigan ko nag pakabit pero sa montero na VGT at umaabot daw sya ng 25psi ang boost.
mga sirs here is a pic of my truck. I am planning to change the rims from 16x8 to 16x10. Gusto ko sana lumabas pa ng konti from the fender. Question, hindi kaya sya mag rub pag full turn? Stability issues? At kung saan po pwede bumili ng mura. Your opinions would mean a lot. Thanks!
+20 ang offset. Also nag lagay ako ng 1/8" spacers front and rear para lang lumabas ng konti. Pero bitin pa rin. Thank u for the insight bro..
if you want lang naman na lumabas yung mags and tires what you need to have is a negative offset wheels....=) masyado na malapad 16x10 IMO and hindi na yun kaya ng 265 iacommodate...
Yup, hanggang 16x9 lang ang 265/70r16 or 265/75r16. Pwede din bolt-on wheel spacers gaya nito:
http://image.4wheeloffroad.com/f/245...l_adapters.jpg
Pero mahirap ata maghanap ng 6x5.5 (139.7 pcd) to 6x5.5 (139.7 pcd) pattern.
finally, nakakuha na rin ako shoes for my 2010 GLX! pa'no po ba mag post ng pics dito? hehe..
got 16 x 8 offset +20 (as advised by people here) and PERFECT siya for me since wala ako fender flares. looks great with 265/70/R16. achieved around 1/2 inch from the edge of my fender and no issues when turning, etc. (again, as indicated by my "advisers" on this thread). salamat ng marami!
kung may flares, baka ok +10 or even 0 offset. ganda siguro nun since ang lapad ng inner lip! my two cents..
on to another topic, meron na ba source dito sa pinas ng honeycomb grills (ie. stock on triton releases in thai, australia, etc.)? tagal na'ko naghahanap. if wala, has anyone ever tried purchasing online? any issues with customs?
thanks ulit mga sir!
^ I like to make a PRIVATE album on Facebook and put all my hosted pictures on there. Get all the image links from the individual pictures, then post a reply here sa tsikot, and paste each of the links after pressing the image button above.
