Results 651 to 660 of 1640
February 26th, 2011 12:39 AM #651
^I was actually referring po sa inserts sir...However if you want to have your door handles black, you can actually paint it...another is that you can also search someone that has a GL unit and wiling to have your chrome door handles traded with his plain black ones....HTH...
February 26th, 2011 07:51 PM #652
re: Headlights Switch (hi/low)
Inaaalign ako ng headlight ko kanina (sinundan ko ang instruction ni Arvin kung alin turnilyo ang pipihitin).. Napansin ko lang, pag switch ng high beam medyo nababawasan ang liwanag sa low-beam (nag off ang low beam) pero kung naka low-beam ka lang at mag FLash lang ng high-beam parehas sya naka sindi. Normal lang ba eto na automatic mag off ang Low-beam natin pag nag high-beam tayo. Pwede ba modify ang wiring na pag nag switch tayo ng highbeam eh yun low beam naka on pa din ;)
yun mga nag upgrade sa Angel eyes, ganyan din ba ang switch nyo? pag high-beam patay yun isang ilaw? or ginawan nyo ng separate switch? baka me diagram kayo dyan ;)
thanks
- Sep 2006
- 110
February 27th, 2011 02:30 AM #654tekken - yup lahat ng h4 bulbs ganyan namamatay tlga ung low pag nag hi
February 27th, 2011 09:55 AM #655
February 27th, 2011 02:45 PM #656
*martin/nismo
Thanks. Pero pwede ba lagyan or modify ang stock h4 bulb na pag nag hi beam ako hindi mag off ang Low beam ?
February 27th, 2011 06:45 PM #657
partner pwede naman gawin, ang problema lang is yung paglagay ng bypaa line going to the low side coming from the high side. baka kasi magkamili ng paglinya mag salubong yung current sunog ang wiring at relay ng mga ilaw niyan, it is doable, pero i don't see the point as to bakit mo pa kailangan gawin?
February 27th, 2011 08:42 PM #658
- Sep 2006
- 110
Ang tagal na ibinalita yang ban. Tapos warning pa ang ginawa first few days. Yung mga nahuli pa...
E-bike / E-trike ban details released by MMDA
