Results 1,511 to 1,520 of 1640
March 2nd, 2012 05:35 PM #1511
I've read that some have problems with wheel alignment after installing strut/coil spacers on their trucks to achieve a leveled or lifted stance. Could this ball joint spacer be the solution or the missing piece?
Mitsubishi L200 Triton Offroad: Step up 2 inch body for Mitsubishi L200 Triton offroad
TRITON ML 4X4 MODEL 2 INCH LIFT KIT
Paging sir bigblock and sir mdksael.
March 2nd, 2012 11:14 PM #1512
Rims have more visual impact than tires so I would suggest that you change your rims first. 16" x 7" would still fit your stock tire. If you have enough money to change both rim and tire then you can go 17", 18" or higher for better overall appearance of your vehicle .
- Oct 2003
- 101
March 3rd, 2012 05:48 AM #1513bai,
in my place, the shop that installed my suspension kit is known to use this method, spacer at the top of coil. sa montero, a 5/8" spacer will raise 2" sa front height to level the rear. baka same din sa strada. it is recommended to replace the shocks to a long-travel type (mostly aftermarket) kasi the stock shock has little more room to play. after that pina wheel alignment lang at wala naman daw problema sa ball joint.
March 4th, 2012 06:21 PM #1515
Thanks sir G01!
Hmm.. To lift or not.. Ride is only a 2.5 4x2 non-vgt with 3.9 gear ratio. Would there be any problems if I upgrade to 32x11.5r15 (290/75r16 equivalent) all-terrains aside from fuel economy?
I read kase that 31" tires is good for 3.9 gear ratio for uphill power with heavy loads (loads will be occasional though). Or will a performance chip be needed when up-sizing the tires?
Shocks will most probably be Ironman nitro gas with strut/coil spacers, ball joint spacers, and rear lift blocks with new U-bolts.
March 4th, 2012 09:38 PM #1516
I know some 4x2 non-vgt Strada owners that had their rides lifted by 2" and are using either 265/70 or 265/75/16 AT tires. Jeff's Offroad Shop did a 5" lift on both 3.2 4x4 and 2.5 4x2 and fitted both with 33" tires. Jeff told me he was surprised that the 2.5 has better acceleration than the 3.2. Are your rims 15"? Not sure if 15" will have enough clearance for the brake rotors unless the rims have sufficient negative offset.
The Ironman kit, I think, doesn't have coil spacers because the shock itself is longer with longer set of coils but the added height is only 1.5". The rear leaf spring is also longer so lift blocks are not provided.
- Jun 2011
- 7
March 5th, 2012 01:23 PM #1517sirs good afternoon,ask ko lang how much kaya yung steel bumper na finafabricate ni bigblock and manong sael? new strada owner here from las pinas,when pala next eb so i can attend and para makapagpa member na rin? TIA
March 6th, 2012 11:54 AM #1518
Been using 15x9 wheels with +12 offset (5-inch backspace) for almost 2 years. Space is just enough to clear the brake calipers. Plan to use custom coil and ball joint spacers and rear lift blocks with longer U-bolts. Only the shocks will be from Ironman (I read that their Triton shocks are applicable for 0-50mm lift).
Did the 33" tire-mounted 2.5 with better acceleration have VGT?
March 6th, 2012 04:08 PM #1520
Good that you didn't have problems fitting the 15" wheels.
I the Ironman shock gives a 50mm lift by itself so adding a coil spacer will extend the lift further. Please correct me if I'm wrong. Mine is 3" with extended upper arms and front differential lowering bracket so the CV joints are not angled too much.
AFAIK, the 2.5 with the 33" is not yet VGT equipped.
Latest mileage:
