Results 191 to 200 of 272
- Nov 2009
- 14
March 25th, 2010 05:15 PM #191Thank you very much Mr Hilario for the excellent suggestions. I will do as you say and try to perform them as stated. I actually read through your previous emails and was able to go to Hybrid months ago and got the rain gutters. Like you, I am very happy with my Actyon and I see to it that it is functioning properly and serviced on time.
As I write this, my reverse sensors apparently just died on me and I will see if this is covered by the warranty as well, when I take it to Wheels for a check up.
Around 5 months ago, I was cruising on the Skyway at 140kph when suddenly, the engine just went on engine-break mode to go down to around 100kph, and the check engine pilot lamp lit up. I went down on the Don Bosco exit to go straight to the Ssangyong Makati dealership. They just told me to leave the car as they will reset some sensor. Their explanation was that there was a rev-limiter activated and they had reset the same to allow the car to take the higher speeds. The incident hasnt occurred again.
I wonder if any of our co-owners had experienced this.
Again, maraming salamat and drive safe everyone!
- May 2008
- 14
March 25th, 2010 06:58 PM #192Actyonman, if I may ask what Actyon model do you have? Where did you bought your actyon?
Based on the max speed on our actyon, it should be able to reach 200+Kph, and a rev limiter if there is one should activate before going beyond the maximum speed. I just wonder why this is the reason given to you by Ssangyong makati.
I actually bought my actyon in Makati, and I find their price to be high so I decided to go to ssangyong main in e. rodriguez which is much lower in price.
E. rodriguez has some actyon accessories being sold, comparing it to the internet price their price is OK. Just bought a luggage cover, chrome garnish for headlight, rear taillight, and window accent. Also gotten a rear fog lamp installed by e. rodriguez. A front & rear bullbar 2" diameter bar was customized locally and got the idea from the internet as to the design, it turned out to be nice and very unique.
March 25th, 2010 07:41 PM #193
- Nov 2009
- 14
March 26th, 2010 04:28 PM #194
I bought my Actyon Diesel 4AT in Ssangyong Makati last August 2008. I just put 1 pc rear foglamp on the left side, and the window accent.
That was the only reason the guys in Makati told me. Its working fine -- have been enjoying the vehicle since I got it. Sana we could have an eyeball for the group one day. How about it guys?
- May 2008
- 14
March 29th, 2010 01:31 PM #195Na una lang pala ako ng isang buwan sayo actyonman, got mine July 2008 in Ssangyong Makati also. I assume what the Makati ssangyong did is just removed the error code using a SCAN 100 reader. If another check engine happen just turn off your engine the rev limiter is activated for every check engine error. To reset the rev limiter just turn off your engine then on again. And make sure to bring it to e. rodriguez you might have already experienced a vacuum regulator problem causing the check engine, this is usually the problem encountered by casa for our actyon. They will also do cleaning of your EGR valve if need be. I usually fill up with petron diesel before but after it was fixed decided to use shell instead, since they mentioned carbon deposit which is usually a bi-product of diesel if not that clean.
Make it a habit as well every qtr/semi-annual to use diesel fuel injector cleaner or any equivalent which is usually mixed for every 35+ liter/full tank. This will ensure everything is burned up properly in your engine. I already used Liquimoly Diesel Purge parang bago uli takbo I think you know the feeling already.
I'll try to post some PICs later. Enjoy your actyon very unique ang porma nito head turner pa rin up to now.
- Nov 2009
- 14
March 29th, 2010 02:34 PM #196
- Nov 2009
- 14
April 23rd, 2010 04:32 PM #197
Hi Mr Hilario. I did as you advised. All done including the fuel injector additive. I think I have the same problem you had encountered. The vacuum regulator. I noticed that there was a moisture and some oil coming out of the area near the regulator. I shall proceed to E Rod on Tuesday and have them look at it. I hope that they will fix it for free too. Otherwise, I will let all of you know.
June 6th, 2010 02:32 AM #198
- 42
June 28th, 2010 10:52 AM #199Peeps...it turned out that the vibration problem Im experiencing with my Actyon is coming from the transmission....Wheels need to replace the whole assembly but unfortunately I have to wait for the replacement unit since they dont have a spare in the country....bad trip....
Hope you guys dont ever experience this kind of hardship (being without a car) Im undergoing despite the fact that my Actyon is just a mere 1 1/2 years....with just around 20K mileage.
- 42
July 22nd, 2010 02:13 PM #200My transmission was replaced finally ...got back the car last Saturday. So far so good.
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
