Results 131 to 140 of 272
- May 2008
- 14
February 6th, 2009 09:21 AM #131Hi, I am now nearing 10,000 KM eventually will need to undergo the 10k maintenance. I have already asked Ssangyong E. Rodriguez on the type of oil but no clear answer was given to me as to the brand or SAE specs used. Anyway I made a research on this and based on the manual of an Actyon Diesel the oil used should be MB 229.1 or MB 229.3, so whats the equivalent SAE code for this I just discovered that MB 229.1=SAE 10W40 and MB 229.3=SAE 5W40, just make sure to get the right oil for a GAS or a DIESEL engine since they both share the same SAE code. To identify if its a diesel oil look for this spec rating which starts like C or B, or both. Ex. CG-4, CH-4, CI-4/SL.
Well I'm planning on my next oil change to use my preferred oil and may not be done in CASA. I have read a lot about Royal Purple I might try the 10W40 fully synthetic.
My current Fuel consumption I am averaging 10 KM/L pure city driving, travelled area is Las Pinas, Coastal Road, Roxas, Intramuros, Pasay, Makati and back the same route. I also enjoy filling up especailly now a days diesel prices is much cheaper compared to gas by almost 3-4 pesos.
At macapagal its around 26~27 per liter diesel price.
- Oct 2008
- 259
February 6th, 2009 06:39 PM #132thanxs rhilario sa info naka buy ako rain gutter sa hybrid....mura pla step board sa kanila kso white n lng natira...
March 3rd, 2009 03:38 PM #133
Hirap maghanap ng gulong same as the factory installed sa Actyon. Got one busted dahil sa malaking piece of metal na bumaon at dahil sa laki ng puncture, di na kaya ng patching. Any advise san kaya makakabili ng kaparehas nito? Try ko sa secong hand tire shop baka kako may Actyon owner na nagpalit ng set of tire na pero wala din eh. Naka 2500 KM na Actyon namin at no dramas pa rin naman. Lakas pa rin ang hatak
April 16th, 2009 12:13 AM #134
Checked out HYBRID for some Actyon accessories. Maganda yong stepboard specifically made for Actyon imported from Korea kaya lang white color lang available at blue ang unit ko. Did 4100 KMS na and no problems or whatsoever pa rin naman. Max speed I did with my Actyon is 185 KPH sa SCTX with 5 adults onboard. Sarap ihataw
Tsikot Member Rank 4
- Jan 2007
- 2,326
April 16th, 2009 06:20 AM #135
April 22nd, 2009 04:51 PM #136
That's what I did. bumili n lang ibang brand na same ang size at similar and pattern. Di pwede and reserve since iba ang size at marked as an emergency spare lang talaga. Ito ang na discover ko sa Actyon na hindi maganda, spare tire specs is not the same as the actual running tires.
- Jan 2007
- 2,326
April 23rd, 2009 12:58 AM #137
- Oct 2008
- 259
June 28th, 2009 08:37 PM #139
- May 2008
- 14
June 29th, 2009 08:41 AM #140Naka document yan sa owners manual on how to replace the aircon filter. Or you can download it sa Ssangyong website. Pabugahan nyo nang compressed air to remove all the dirt, can be done with any gas station for a small service fee like 20+ pesos only. It has two microfilter orig price is around php 1,900.
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
