Results 3,071 to 3,080 of 3844
January 12th, 2013 11:08 PM #3071
Sir eh hindi ko din alam. October 2012 po siya na-overhaul. After so many years of running on water alone. After the overhaul, we put in the correct coolant mix. One of my pals says that the coolant might have dislodged the sediments and rust that have built up over the years and a lot of it ended up in the radiator. I hope this is the end of it. Keeping my fingers crossed.
January 12th, 2013 11:25 PM #3072
Baka nga sir. Yung mga naiwan na sediments sa engine block and heater. I hope nadrain niyo na din yung engine block for remaining contaminants
- - - Updated - - -
January 13th, 2013 12:25 AM #3073
Wala na kami makuha sir. Lahat ata lumipat na sa rad. hehe.
Still, I'm praying that this is the last of this overheating $hit so we can finally tear out the interior and start hauling patients.
January 13th, 2013 12:30 AM #3074
guys.. tanong ko lang po sana kung alam niyo speaker size ng mb100 sa door sa harapan? thanks
- - - Updated - - -
January 13th, 2013 02:51 AM #3075
January 13th, 2013 10:11 AM #3076
Di na po kami nag dagdag. Ok pa daw po. Yung reason daw bakit ayaw mag engage ay dahil wala nan water flow dun sa radiator tapat ng clutch fan kaya po wala na siyang init na mapick up.
January 13th, 2013 12:25 PM #3077
- Oct 2009
- 70
January 13th, 2013 07:01 PM #3079Good PM mga sirs, just finished having the van fixed. Change belt, water pump, filters, glowplug and oil. ALthough 1 click andar na siya now, ang problem is ayaw naman mag shut off ang engine so i had to put it to first gear at pakawalan ang clutch para patayin ang makina. Ano kaya mga sirs ang problema nito mga sirs. And another thing na i noticed is after some time na umaandar ang van, biglang umaandar ang glowplug light.
January 13th, 2013 08:24 PM #3080
Grabe Sir Doc baradong barado pala ang radiator niyo.... yung case ko naman po malinis talaga at hindi nag babara ang radiator ko nung bumalik ako sa 2 rows at nag adjust ng thermal spring sa fan clutch saka lang naging maayos ang cooling system ng engine ko...
Because pinoy mentality. Not surprising.
