http://www.mercola.com/nutritionplan/index.htm
When does that happen? 1. During starting? 2. While the vehicle is idling/running?
speaking of... many years ago, my 1976 toyota corona RT100 's battery ran flat. the culprit was a...
aside from those mentioned above, pwede din hindi na maganda ground/grounding ng sasakyan niyo.
noted. some literature warns not to mix the green with the red, even as others say fine. i prefer...
To add, the Civic FD uses Honda Type 2 coolant (blue color). It is long life and it's the coolant...
Naka coolant po ako before mangyari tong mga to, and meron din po ako pwedeng ilagay ngayon kaso...
Not sure if its normal ba, pero pag kaka start po may usok na white sa exhaust, tapos nung pina...
Enter your email address:
Delivered by FeedBurner
ALTERNATOR. Repair or replace?
