Results 1 to 10 of 13
- Jan 2003
- 23
March 3rd, 2003 11:32 PM #1guys,
tanong lang...saan po ba mas prone na mabukolan ang gulong, pag under inflated o over inflated ang gulong?
salamat po!!!
March 3rd, 2003 11:59 PM #2
under inflated tire... too much flexing of the sidewall as your tire rotates can work loose the layers of the tires.
- Jan 2003
- 23
March 4th, 2003 12:19 AM #3ghosthunter,
maraming salamat!!! :D:D
huling tanong po, ano naman po ang disadvantage kapag over inflated ang gulong?
salamat uli!!!
March 4th, 2003 12:42 AM #4
Mas matagtag ang ride and overinflating it beyond the recommended maximum may reduce tire life at madaling pumutok in cases of extreme stress.
4x4ph.com
- 695
March 5th, 2003 05:05 PM #5lagay mo nalang sa middle ng range na binigay ng manufacturer. kasi kapag umiinit ang mga gulong nag-e-expand so tumataas ng konti ang tire pressure mo...
March 5th, 2003 05:21 PM #6
or if you want to up your gas mileage.. add 2-4 psi from your recommended tire psi.
it won't hurt your tires.
peace.
- Jan 2003
- 23
March 6th, 2003 12:28 AM #8ah ok!!! maraming salamt po!!! nabukolan kasi yun isang gulong ko sa harap e...
ngayon hindi na magyayari sa akin ulit yon!!! :Dah ok!!! maraming salamt po!!! nabukolan kasi yun isang gulong ko sa harap e...
March 6th, 2003 12:53 AM #9
BTW, hitting something wth your tire's sidewall can also lead to "bukol". It happened to my Goodyear Eagle NCT3 before. when I hit the damaged curb of a sidewalk.
- Feb 2003
- 10
March 6th, 2003 08:51 AM #10lestat,
no ba brand ng tires mo? kc kung lemans dunlop yan particularly yung LM 701 madaling mabukulan yan parang sakin 2 front tires ko ngkabukol. m sure naman na ndi underinflated ang mga gulong ko and ndi rin naman ganu malubak from bcutan 2 laguna kung meron man kabisaado ko na ang kalsada.... and lagi ko naman cla panapahanginan everytime dumadaan ako s gasolinahan.
Eventually this undetaking has to take place but it is the planning and coordination that is...
