Results 2,641 to 2,650 of 3900
Tsikot Member Rank 2
- Aug 2005
- 375
October 31st, 2005 11:33 PM #2641Originally Posted by kmo
November 1st, 2005 12:22 AM #2642
ilovedetailing , johnnyd :: sir hindi po battery eh ,gumagana naman po yung horn ko and hid and stereo pa nga eh... .. sayang punta pa naman kami sa baguio hehe
pag start ko feel ko parang sira ang fuel pump ....pano na po yun pag pina service ko sa nissan hahatakin ba nila papunta sa casa? and na kuha ko sa nissan un pero malapit ako sa universal motors pwede ba pa service ko na lang sa universal motrs ma-claim ko ba yung warranty ko if ever ty po
Tsikot Member Rank 3
- Dec 2002
- 636
November 1st, 2005 04:02 AM #2643Originally Posted by erict
Conoco's Hydroclear Power D 15w40 is their highest grade diesel/gas oil rated at CI4 plus/ SL which is the same rating as the Nis-syn oil, coincidence? Think Nissan ordered the Power D 15w40 but rebranded it as Nis-syn synth oil, but they don't call it a full synthetic oil.
November 1st, 2005 06:12 PM #2644
sa mga kasama natin na mahilig mangalikot, eto yung how to change your ventilation filter or i-cabin microfilter. sabi ni zeagle 2500 daw ang isa. zeagle, wala pa ba tayong substitute para dito?
Removing the filter:
1. The glove box is held in place by 2 pins as shown below:
November 1st, 2005 06:14 PM #2645
2. Remove glove box by pushing the 2 pins towards the center of glove box.
3. The filter cover for the filter is now in full view. The arrows point to the tab locks.
November 1st, 2005 06:14 PM #2646
4. Place your thumb on the tab lock w/ the word push while your forefinger is on the underside of the tab lock pushing towards you.
5. Filter is now in full view:
6. Replace filter & reinstall glove box. If you will clean the filter, instructions are below.
Cleaning the Filter Element
1. Soak filter in a solution of mild strenght detergent and water
2. Move filter lightly through solution to clean
3. Rinse w/ tap water
3. Dry filter thoroughly before using it again.
Note:
a. Filter could become mouldy if left in a moist state
b. Once cleaned filter can be used 1 to 2 more times
c. Replace the filter if after cleaning the filter should not function properly
According to the maintenance manual, the ventilation filter should be replaced every 30k kms. But after seeing the filter, IMO it would be best to clean it at 10k kms. & replace it by 20k kms.
Tsikot Member Rank 4
- Oct 2004
- 1,054
November 2nd, 2005 08:33 AM #2649
wala lang magawa. ang tagal ng bakasyon.
pero pansin ko mas malamig ngayon yung aircon.
** Remember the orientation of the filter when removing it. baka baliktad ito when you return the filter.Last edited by johnnyd; November 2nd, 2005 at 08:37 AM.
November 2nd, 2005 10:35 AM #2650
Thanks for the info. I check parang may rattle sound galing dash board ko.
2021 Nissan Leaf
