Results 1,601 to 1,610 of 3900
Tsikot Member Rank 4
- Oct 2004
- 1,054
July 8th, 2005 12:52 AM #1601hindi ba sobrng kapal na nyan? 225/70?
hmmm it should inmprove fuel milage pero bakka dahil lang sa kakahataw ko tsaka traffic rin kasi minsan papasok e tsaka super mixed driving ako highway city etc etc so de rn masabi hehe
July 8th, 2005 01:02 AM #1602tire pressure at 35? hindi ba sobra tigas ng ride nyan? mine is 28 only, as suggested by the tire dealer. i installed kasi 225/70 series nexen tires.
How much for the tires?
July 8th, 2005 01:34 AM #1603
Yourman you might want to reconsider your tires. Parang wala sa specs which will affect your fuel consumption.
- Oct 2004
- 1,054
July 8th, 2005 02:56 AM #1604oo kasi tingin ko pag 225/60 kna dapat e kasi pag nilaparan mo ninipisan mo dapat para patas parin pati sa speedometer mo de magbabago
yung stock kasi is 215/65 so 225/60 ata dapat
July 8th, 2005 08:56 AM #1605
Originally Posted by zeagle
iluvdetailing: angtire pressure ko ay 30. i read somewhere about fuel saving tips, you should inflate your tire at least 2 psi over the recommended pressure. sa xty natin ang recommended pressure ay 28 kaya 30 ako lagi.
July 8th, 2005 08:58 AM #1606
A stock tire 215/65/15 changed to 225/70/15 will have a 5% reduction in rpm or if you are traveling 60mph, you are actually going 63mph. Yourman what is the rim size that you used? Did you changed the stock rims?
July 8th, 2005 10:02 AM #1607
FYI Tire size calculator -> http://www.miata.net/garage/tirecalc.html
HTH.
July 9th, 2005 02:24 AM #1608
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
215/65-16 5.5in 13.5in 27.0in 84.8in 747 0.0%
225/70-16 6.2in 14.2in 28.4in 89.2in 710 5.2%
Seems that the change in tires would result in lesser rev/mile than the stock tires, does this mean savings in fuel?
I didnt change the rims, I retained the stock rims. Actually I was lookin for 235/70 or 235/65 tires but these are hard to find here. So i settled with the 225/70 tires.
The dealer was offering 235/60 so as not to change the diameter size of the tires from the stock, but i really wanted to increase it to make it taller. shall nissan casa re calibrate the computer program to be consistent with the change in tires?
By the way, i increased the tire pressure to 30 psi as advised by some of you. thanks for the advice. please dont hesitate to give more gas saving tips.
thanks.
July 10th, 2005 01:55 AM #1610
Yourman I think your new tiresize is same as RAV4. I don't know what is the effect though.
2021 Nissan Leaf
