Results 1,481 to 1,490 of 3900
Tsikot Member Rank 4
- Oct 2004
- 1,054
June 19th, 2005 02:04 PM #1481yung foglights is h3 yung bulb yung park light regular peanut bulb lang yun !
and yup ! the regular filter is just made up of ordinary carton hehe yung specs and size is natatanong naman yan e depnds sa brand na balak mo knn or hks meron yan sabihin mo drop in filter
June 19th, 2005 04:22 PM #1482
Originally Posted by yourman
pag led light ang gamit, maliit ang draw sa current. ang kaibahan sa regular light, ang led bright at the source pero projected light to a target mahina. para malaman ang brightness ng led look at the mcd rating (millicandela). the higher the mcd the better. 1 led bulb, lets say for the clearance light is made up of up to 9 individual leds. each led is measured in mcd. total mcd is individual mcd x number of leds. meron kasing mga bulbs na marami bulbs pero maliit ang total mcd.
if you are going to change your signal lights to led, you might need a load resistor kasi halos walang load ang led, it might signal na pundido na ang buld kahit buhay pa ang led. if you are going to change your signal lights & the cover is amber, get an amber led. if for the brake & rear lights get red kahit red na ang color ng cover. sabi mahahighlight daw yung color.
for more info click here
read the notes concerning tail/signal/brake lights. hope this helps.
pahabol: if your are adding drop-in k&n filter for 2.0 xty, part number is 33-2031-2. kung 2.5 xty ang part number ay wala.Last edited by johnnyd; June 19th, 2005 at 04:30 PM.
June 19th, 2005 08:14 PM #1483
kmo: yung HKS Filter may oil ba? baka kasi masipsip yung oil.
Johnnyd: Dun ka ba nag order ng LED? Magkakabit ka din ng HKS Air filter?
- Oct 2004
- 1,054
June 19th, 2005 08:28 PM #1484ILD: wala foam lang siya ! pero sa alam ko khit naman may oil de rin masisipsip e mga knn mern oil kasi
June 19th, 2005 08:31 PM #1485
KMO: Pag nag EB patingin naman ng Airfilter mo. hehehe. San mo pala nabili? Magkano uli? Nakalimutan ko na.
June 20th, 2005 08:29 AM #1487
June 20th, 2005 12:43 PM #1488
Isa isa lang, mahirap sabay sabay hehehe... mabigat sa bulsa
Teka kala ko nakabili ka na ng rear fogs?
- Oct 2004
- 1,054
June 20th, 2005 03:09 PM #1489kaya yan ! taya kayo ng lotto ! hehehhe pag nanalo ! WOW !!!! mods galore !!!
- Jun 2004
- 252
A/c
