Results 1,401 to 1,410 of 3900
June 9th, 2005 03:57 PM #1401
yung air-filter ba kailangan bang every 10K kms? Nung pinaservice ko, lininis lang yung air-filter element.
Tsikot Member Rank 4
- Oct 2004
- 1,054
June 10th, 2005 01:35 AM #1402pero iba talga filter natin e karton lang talaga grbe ! de ko alam kung filter paba yn e hehe
- Oct 2004
- 1,054
June 10th, 2005 02:41 AM #1404yung sa hks gamit foam type e ! mas high flow talga ! tsaka mas mukhang nakakafilter if ever compared sa karton ng stock natin hehe
- Oct 2004
- 1,054
June 10th, 2005 02:30 PM #1406ok knina galing ako sa nissan .. tiningnan ko xtrail ko at nakausap ko yng 2 techinciam ok naman e mababait hehe problema sa kotse ko hehe wala daw time table kelan maayos kasi medyo complicated daw sira e electrical daw parng ngaoyn lang daw nangyari to !!! sabi sakin kasi una bago pa kotse ko so yn yung unang problem
ginawa daw nila una is pinalitan ng bagong ecu pag palit ganun parin daw so kala nla instruments may sira pinalitan na ng bago ganun parin daw so ngaoyn kinalas na nila yung buong dashboard hinahanap yung isang wire daw na nagcacause ng lahat ng problems pag punta ko knina nakakalas e hehe tpos de pa daw sure kelan maayos dahil yun nga ngaoyn lang daw to nangyari tpos nakita ko dami mekaniko nag aasikaso mga 4-5 knina e hehe tpos nakalabas na mga manuals nila at mga instructions kung paano ayusin ... tpos yun sabi wala pa time table ..
- Oct 2004
- 1,054
June 10th, 2005 02:55 PM #1408de pa nila alam e pero tinnag ko kng dahl ba sa mga exhaust ko at filter sabi nung tao de daw imposible malamng daw sa pag assemble dati
may mali daw
June 10th, 2005 04:32 PM #1410
baka nga may nagshort o may bumigay na sensor. at least hindi ecu ang bumigay. matatakot tayong lahat pag ecu ang bumigay.
It helps that the three generations of the leaf share the same battery formfactor and can use the...
2021 Nissan Leaf
