Results 381 to 390 of 5910
June 5th, 2005 08:14 PM #381
Woo! That's great! Good thing I bought extra spray bottles! Thanks Groucho!
June 5th, 2005 08:51 PM #382
Don't forget to cover your alternator, what i do is cover it first with a rag then plastic, no need to be watertight just enough to repel water and I don't power spray the engine, just rinsing will suffice.
Since your mazda should be a relatively new, no need to use a heavy strength dilution. 1:10 SG/Water should be enough.
- Nov 2003
- 190
June 5th, 2005 09:29 PM #383ILuvDetailing is right. Never power-spray with water. If you do, you're no better than the guy at the neighborhood gasoline station who does engine washes.
I know of some diehards who wrap the alternator and the distributor with aluminum foil instead of just plastic. They say that way, they feel safer that water will not seep into the electrical parts. But aluminum foil can be quite costly. Like I said, they're die-hards.
And one more tip, patopig: spray the SG/water mixture while your engine/engine bay is still warm. The relatively high temperature helps in the degreasing process.
June 5th, 2005 10:04 PM #384
don't go full strength with an APC while doing the engine.
for degreasing, i'm at 5:1. that ratio suits me well. after cleaning, spruce up the bay with some dressing.
no need to power wash. and like all people said, cover the essential parts. this can be done by rags later. try to look for Engine Kote (if there's still any here in the Philippines). Better than Hyper Dressing IMO.
- 290
June 6th, 2005 10:45 AM #386Originally Posted by morrissey_05
- 290
June 6th, 2005 10:49 AM #387Originally Posted by patopig
June 6th, 2005 11:49 AM #388
Hello again bros. I was able to wax my car with prestone high protection wax last night. After buffing, the paint was really slick and shiny.
I do have some pictures below. (Taken this morning, rushed because it was a light drizzle going on.)
June 6th, 2005 11:52 AM #389
patopig: Nice Work again. Red on a Mazda really looks good!
BTW did you do a 3-step on your ride? or just wax?
June 6th, 2005 11:56 AM #390
Have not done the trim/tires yet. Will top with Mothers Phase3 Carnauba (Liquid) tomorrow!
byd seal5 dmi. that coolant tank is the same setup like in the fords. plastic coolant lines :twak2:...
BYD Philippines
