Page 254 of 257 FirstFirst ... 154204244250251252253254255256257 LastLast
Results 2,531 to 2,540 of 2561
    Feb 2019
    #2531
    '96 EL of my relative showing oil leaks/spreads on the oil pan (front portion) and its surrounding (see photo... it might be rotated clockwise automatically when I attach it here). Very slow drip in garage floor. Oil stick level within min-max range for the 1++ years since last oil change. Is it due to the Oil Pan Gasket/Sealant? or Cylinder Head Gasket? or something else?
    Edit:
    ^--- Posting some more photos in landscape:
    Any suggestions what part to replace/repair? Thanks!
    Feb 2019
    #2532
    Sorry.. double post (deleted and merged with post above)
    Attached Thumbnails Attached Thumbnails 20200721_162018.jpg   20200721_140351.jpg
    #2533
    Quote Originally Posted by auto_enthusiast View Post
    Edit:
    hard to see where the leak is coming from.
    you will have to clean the area free of oil, then observe from where the oil first appears.
    Apr 2024
    #2534
    Mga ka lancer itlog problem ko may start ako na 1.8rpmi tapos natigel Ng 1.5rpmi kahit mainet na para bumaba need pa re start ano kaya problem sino naka experience na Ng ganito , share Naman ddyan
    #2535
    Quote Originally Posted by Rjmar View Post
    Mga ka lancer itlog problem ko may start ako na 1.8rpmi tapos natigel Ng 1.5rpmi kahit mainet na ipapara bumaba need pa re start ano kaya problem sino naka experience na Ng ganito , share Naman ddyan
    let me understand...
    when you first start the cold engine, the rpm is 1800, then when the engine is hot already, it is still as high as 1500 rpm?
    then when you shut down the engine and immediately re-start it, the rpm then settles at the prescribed 900-1000 rpm?
    hmmm...
    errr,
    how does your rpm go when you turn on the aircon?
    Apr 2024
    #2536
    hmmm...
    errr,
    Ok na when it settled 900 but sometimes still baliktad pa din when ac off rpm up then ac on going down
    #2537
    Try cleaning the throttle body. But more likely the servomotor is broken.
    Apr 2024
    #2538
    Tried cleaning and replace servo with throttle body build in but still the same issue
    Apr 2024
    #2539
    Gamet ko cone filter kapag ba malakas Yung higop Ng hangin servo motor na tlaga sir
    Apr 2024
    #2540
    hmmm...
    errr,
    Kanina result Ng nag settled sa 900 nag turn ako Naircon nag dropped Minsan umaangat sir pero kapag nag accelerate dunadrop pa din
