Page 170 of 185 FirstFirst ... 70120160166167168169170171172173174180 ... LastLast
Results 1,691 to 1,700 of 1842
    #1691
    Babala
    Sink hole beneath naiax
    https://twitter.com/ABSCBNNews/statu...NWyG66M5w&s=19
    Sent from my RMX3690 using Tsikot Forums mobile app
    i wonder what caused it.
    it don't look like a natural sinkhole in the geologic way,
    is it possible, the leaking water eroded away the ground, causing it to sink...?
    #1692
    Most probably a busted main water line somewhere deep underneath. There has been a depression there for the longest time. Finally broke through.
    #1693
    Babala
    Yung nakakatakot is the post of the NAIAx skyway is right beside it... di alam ganun ka lawak at lalim ng sinkhole.
    #1694
    i wonder,
    parang meron akong malabong natatandaan,
    did this start as a very slight depression on the asphalt road of several months old?
    #1695
    Sinkholes are ninjas. Unless you regularly test (using sonar? ground penetrating radar?) they happen with no warning, and usually there's no reason to test naman.
    Having good construction might make it even worse because the road doesn't collapse until the sinkhole is really large.
    Massive sinkhole causes highway to collapse in Ohio, USA - BBC News
    #1696
    I remember passing sales road last good Friday and there was a construction going on along that stretch. I'm not sure if that's the exact location though.
    #1697
    Some areas are prone to sinkholes such as areas with limestones as the bedrock and areas with cave systems.
    #1698
    suspended ba ang coding ngayon on all fronts?
    ang problema may rally pala jeepney drivers. baka traffic din
    #1699
    i hope so!
    ilalabas ko si #5 EP car ko today.
    from what i understand,
    as per policy,
    coding is suspended on holidays.
    #1700
    i hope so!
    as per policy,
    On regular holidays I think.
Traffic!
