Page 270 of 273 FirstFirst ... 170220260266267268269270271272273 LastLast
Results 2,691 to 2,700 of 2721
    May 2012
    #2691
    First time fueling up - recently obtained a 2015 CX-5 2.0.
    Manual says to use 91RON (minimum). But thinking of loading it with 95. I am willing to pay more if it has substantial benefit both in terms of performance and maintenance (?).
    Driving half city, half highway.
    CX-5 experts, what would you suggest?
    Thanks!
    #2692
    Quote Originally Posted by Renzokuken View Post
    Thanks!
    Negligible, regular is fine.
    Jun 2013
    #2693
    Thanks!
    Unless its a turbocharged car or its stated in the manual to use premium, I'd just stick with regular unleaded.
    #2694
    Thanks!
    not a mazda expert, but
    if the engine computer can recognize the ron 95, it might adjust and give you a bit more km/li.
    otherwise, it's spending more money but for the bragging rights only.
    good luck.
    #2695
    Thanks!
    Stay the recommended Shell FuelSave.
    #2696
    Thanks!
    The SkyActiv engine even though high compression has been designed to run on low 91RON with no knocking.
    May 2012
    #2697
    91 it is. Thank you sirs!
    Mar 2004
    #2698
    Gives more power, not better fuel efficiency ...
    #2699
    1st hand, it'll do both w/ the proper tune. Stock won't squeeze more ponies out premium petrol. OVT used to serve various safe custom Skyactiv tunes, before moving on to Yotas under VFTuner.
    #2700
    Hello, Tsikoteers! Just got a 2012 to replace my coding car, got a good deal but needs a bit of work (engine support, gaskets, etc). I'm from QC, any recommended shops/mechanics and parts suppliers? Willing to drive over to Banawe. Thanks in advance!
Mazda CX-5
