Results 3,381 to 3,390 of 3483
March 24th, 2020 09:09 AM #3381
Well so far 700kms pa lang ako since buying and theres been no diff. Afaik these are supposed to last as long as the usual all terrain.
Handles better by the way over the stock bridgestone AT 693s. Must be due to the thicker 10ply sidewalls. Less flex.
March 24th, 2020 09:12 AM #3382
Btw, what is a better option to do at this point. Change the stock rims to a Rota Trail R 17x8 with a e10 offset (stock i believe is just 17x7.5 e25) for better handling (i think?) or switch shocks to the Tein endurapro plus? The rims are 35k the teins are a bit cheaper.
March 24th, 2020 09:48 AM #3383
Lower offset, wider track, lesser unsprung weight will have some felt benefits on handling, response & aesthetics...but none as significantly felt as having better dampers.
My experience was w/ Koni FSD/Special Actives on compacts & short-stroke suspension vehicles. Not sure how Tein EP+ relatively compares though. I'd suggest hopping on a similar car w/ such a setup to help the discernment
....Or....submit to the tempting & do both.[emoji4] We know you'll really be happier. You'll be helping the economy, too![emoji106][emoji120][emoji4]
March 25th, 2020 09:55 AM #3384
Hehehe thank you sir for the feedback.
The Teins are supposedly an OEM upgrade with better and more aggressive dampening thats adjustable with hydraulic bumpstomps.
Yan na muna but susunod ko rims. Di pwede sabay sabay magagalit si misis [emoji28][emoji28][emoji28]
- Feb 2020
- 10
April 16th, 2020 11:26 PM #3386
Got a set of teins na sir. Bilsteins hehehe. B6 4600. They arent konis but theyre close.
Its hard to believe how big of an improvement these are vs the oem shocks. It feels so confident in handling and high speeds now. Im sure 100% the stock oems are durable but man iba pa din aftermarket.
Tsikot Member Rank 2
- Jan 2008
- 4,726
April 16th, 2020 11:30 PM #3387
April 17th, 2020 12:04 AM #3388
April 21st, 2020 08:53 PM #3389
April 21st, 2020 10:03 PM #3390
Edsa is about 24kms long. So, 15b / 24 is approx 625m per km?
