Results 2,441 to 2,450 of 2721
July 11th, 2019 09:58 PM #2441
July 12th, 2019 10:26 AM #2442
July 12th, 2019 05:56 PM #2445
July 12th, 2019 06:04 PM #2446
July 12th, 2019 07:11 PM #2447
- Oct 2012
- 4,851
July 13th, 2019 11:58 PM #2448Trav bai, have you tried the forscan in your mazda? How dangerous is it? Because i want to enable some code in auto door lock mode feature.m and among others...
As a start, im planning to buy this hs-ms scan..
Hehehe...
July 14th, 2019 01:24 AM #2449
Nope, did not need Forscan for auto door lock, ray bai. Check your MzdConnect settings. You should have options there. You won't even need FS to hook paddles up, just the hardware. If you're tampering AsBuilt codes for gen1 kodo, say to activate cruise control w/ corresponding hardware on non-cruise units, that's when you'll need Forscan. It's safe if you know what you're doing.[emoji4] ForScan may not work on the gen4 M3 BP anymore. Please check if it still does the gen2 kodo like your KF. For tunes, MazdaEdit & EcuTek handle em. Diagnostics? You can use the ELM dongle. I'm partial to ScanGaugeII.[emoji4]
- Oct 2012
- 4,851
July 14th, 2019 01:34 AM #2450
Iyong Amin Ang ginamit ko na oil the last time I topped it off iyong mga Sobra na engine oil ko. So...
Vespa air compressor
