Results 2,401 to 2,410 of 2721
June 23rd, 2019 06:42 PM #2401
Mazda CX-5 released here has both i-Stop and i-Eloop except the first year of the first gen ...
- Dec 2007
- 727
July 3rd, 2019 12:52 AM #2402Im not sure if the CX-5 has i-Eloop because wala naman sa specs...
Sent from my ASUS_X00QD using Tapatalk
- May 2006
- 1,668
July 3rd, 2019 01:11 AM #2404
- May 2006
- 1,668
July 3rd, 2019 01:41 AM #2405Weird. One cannot function without the other. Unless no aircon no accessories during engine stop phase.
No one would buy that.
MAZDA: Brake Energy Regeneration System | Environmental Technology
July 3rd, 2019 02:09 AM #2406
2 separate systems. Mazda's Start/Stop uses combustion, not the starter, to restart. It needs the Q85 EFB or AGM batts for the loads while iStop is activated..
i-Stop and Gasoline Engines
While conventional idling stop systems rely on a starter motor to restart the engine, Mazda's i-stop restarts the engine through combustion; fuel is directly injected into a cylinder while the engine is stopped and ignited to generate downward piston force. The result is a quick and quiet engine re-start compared to other systems and a significant saving in fuel.
i-Stop and Clean Diesel Engines
Unlike gasoline engines, which use a spark plug to ignite the air-fuel mixture, diesel engines compress the mixture until it spontaneously combusts. Therefore, to restart a diesel engine, sufficient compression is required.
While conventional diesel engine idling stop systems require two engine cycles to restart, Mazda's unique i-stop needs just one cycle, thanks to its precise control of the piston positions. As a result, i-stop achieves the world's fastest diesel engine restart time of approximately 0.40 seconds (internal measurement on vehicles with automatic transmission) and its operation is barely noticeable.
iEloop is a fuel saving regenerative braking system using a capacitor.
To see if it has such, look for this Electric Double Layer Capacitor.
- Oct 2012
- 4,851
July 4th, 2019 04:39 PM #2408Will be joining this thread sooner...[emoji4]
I think 2.5 is more than enough for cx-5 for cruiser...
July 4th, 2019 06:22 PM #2409
- Oct 2012
- 4,851
July 5th, 2019 02:21 AM #2410
According to this article, no right of way acquisition is on the table. Which is not to say that...
