Results 2,441 to 2,450 of 2560
- Jun 2008
- 1,741
February 26th, 2017 07:27 PM #2441Paano na ayaw umandar? Malakas ikot ng makina pero ayaw mag fire? Confirm na may fuel pressure after fuel filter (kung meron sa engine bay), before engine.
Sent from my NX549J using Tsikot Forums mobile app
- Feb 2017
- 41
March 7th, 2017 08:40 PM #2442walang kuryente sir.. pinalitan ko ng coil yung distributor..
- Feb 2017
- 41
- Mar 2017
- 6
March 22nd, 2017 12:57 AM #2444gud day mga boss gamit ko is 1995 lancer glxi ang problema is sa start up namamatay bigla at taas baba ang idle tapos pag tinapakan mo gas para tumakbo namamatay wala nmn check engine light.
- Mar 2017
- 6
March 22nd, 2017 01:02 AM #2445nangyari lang to nang kinompression test nmn sasakyan ko sa kalapit bahay may mga gamit kasi siya na nabili ng nasa U.S siya at try ko gamitin sa akin, yung 4 na cylinders lahat nasa 180 psi ok nmn tapos binugahan yung maf sensor with a cleaner ng hapon at pinatuyo, ok nmn pag start at naparada ko pa sa bahay nmn, pero ng umaga na paalis ako bigla na lang namamatay taas baba ang idle tapos pag tinapakan mo ng madiin yung gas lalong ayaw magtuloy at patay ang makina pero wala nmn check engine light na lumalabas sa panel.
- Apr 2008
- 40
March 22nd, 2017 08:10 AM #2446Our Lancer glxi 1994 has been on check engine since several months na. Wala naman ibang issue. Paano patayin check engine? Disconnected battery overnight, nawawala sandali yung check engine, pero bumabalik pa rin. Ano pa kaya icheck?
March 22nd, 2017 08:19 AM #2447
May kelangan palitan na piyesa sir. Or sensor. Kelangan palitan yung faulty part then reset CEL code using obd2 scanning tool
- Mar 2017
- 2
March 28th, 2017 11:35 AM #2448Hi Guys,
Baka po meron kau alam na mabibilhan nong refelctor sa likod ng lancer 94 itlog. ung walang butas na reflector, ung isa kc may butas un sa susian, ung wala pong butas ung nasa left. meron po ba kau ganon? bihin ko na lang kung may available kau dyan.
Thanks po..
- Mar 2008
- 54,258
April 7th, 2017 08:48 AM #2449
- Jul 2016
- 2
April 19th, 2017 11:50 AM #2450
The CHAdeMO plug is definitely a concern. And yes, you are potentially purchasing old tech. In...
2021 Nissan Leaf
