Results 2,431 to 2,440 of 2560
- May 2015
- 5
December 19th, 2016 12:55 PM #2431Thanks po Sir StockEngine..mag change oil po ako dis coming january shell helix 15w40 multigrade (yellow) ok lang po?
- May 2015
- 5
December 19th, 2016 12:59 PM #2432Good Day po..Pa help naman pog mga ka lancer Itlog.. marami po prob Auto ko lancer glxi 1994 itlog
need help and adive po regarding my ride.
1.malakas sa gas around 5-6 l/km consumption. erratic idle, pag umaandar bigla nlng po drop rpm to 300-500rpm parang mamamatay ang auto with AC on..servo po ba prob?
2.pagtumatakbo kahit sa anong gear po biglang tumataas rpm pero wala increase sa acceleration po..pa help naman po. Transmission prob po ba?
kaka tuneup, change oil(shell helix red 20w50),change spark plug, change fuel filter last october 2nd week.
- May 2015
- 5
December 20th, 2016 10:25 AM #2433Good Day ka Itlog's!!! how much po ba ang isang set nang fuel injectors para sa Itlog GLXi 1994?
December 29th, 2016 11:43 PM #2434
Good day, now lang po ako mag post, I have lancer itlog 93 model
with idling problem, naka bypass na pero sa cold start abot 2k rpm, pag maiinit na nag nonormal naman sa 1k pero pag matagal nagamit nabagsak na rpm , ano kaya problem? sabi ng isang mekaniko heat soak daw,
tingin ko baka ecu, kakapalit lang buong distributo bnew. thanks po
December 29th, 2016 11:47 PM #2435
- Jan 2017
- 1
January 14th, 2017 02:24 AM #2436hello po sa mga members dito! nasira po ang aircon compressor ko, sabi po ng mekaniko masyado po daw mataas yun nakalagay, ano po ang compressor para sa lancer 93 EL 4g13 engine v-belt type na pwede na ipalit ko po? thanks
- Feb 2017
- 41
February 26th, 2017 12:52 AM #2437mga sir, tanong lang.. san po ang fuel pump ng lancer glxi 95? TIA
- Mar 2008
- 54,244
February 26th, 2017 01:08 AM #2438my guess? it's in the fuel tank, under the rear seat. in my (non-lancer) car, it is accessed by removing the rear seat, removing the retaining screws of the sheet metal floor cover, to expose the fuel tank underneath. unscrew the fuel tank cover and you should see the pump wading in gasoline. strictly no open flame! not even a cellphone! i am not sure if you should disconnect the car battery before you do this. you probably should.
at least, this is what google told me. google it, po, and see if we read the same thing.
also, check your car manual, po.
WARNING!!! GASOLINE IS EXTREMELY VOLATILE, AND, UNDER THE RIGHT CONDITIONS, WILL QUICKLY FILL YOUR CAR WITH EXPLOSIVE GASOLINE FUMES.
if you are not sure what you are doing, it is best to "leave it to the experts".
GOOD LUCK, SIR.
- Feb 2017
- 41
February 26th, 2017 01:47 PM #2439Thank sir. Sadly hindi po yung fuel pamp ang sira.. i have no clue why my car wont start.
- Jun 2008
- 1,741
February 26th, 2017 07:22 PM #2440Nalinisan na ba ang throttle body, MAP or MAF sensor (kung alin ang meron)? Pa check ang throttle position sensor baka defective. Ang thermostat valve pa check na rin.
Sent from my NX549J using Tsikot Forums mobile app
Okay na ba ang DCTs dito sa traffic condition natin? Diba yung mga Fords na DCT ay...
2022 Hyundai Creta
