Results 2,681 to 2,690 of 3575
July 20th, 2016 10:52 AM #2681
- Mar 2008
- 54,258
July 20th, 2016 10:59 AM #2682
- Aug 2012
- 346
July 20th, 2016 11:10 AM #2683
July 20th, 2016 02:32 PM #2684
- Jul 2016
- 9
July 25th, 2016 03:09 PM #2685
July 25th, 2016 03:11 PM #2686
- May 2016
- 40
August 10th, 2016 02:12 PM #2687Dito ko pala dapat pinopost yung sa maintenance hindi sa detailing hehe.
Guys finally i bought a 2nd hand car and Altis 2009 1.6G black 72k milage ang nabili ko. worth 332k with complete signature sa PMS booklet ng toyota upto 70km.
Dinala namin agad sa hotwheels, pinalitan ng brakepad(OEM 6k), left rear shock(OEM 4.6k) , change oil (2250) cleaned rear brakes.
Sabi nila Filters is ok. Break fluid is ok (lagpas sa max indicator) , coolant is ok (sakto sa max), aligned front wheels. Walang ingay na naririnig. Malakas lang na engine sounds pag in-on ang aircon and mawawala after a few minutes pag inoff ang AC. Our driver mechanic sa office drive it from office to our house, makati to dasma cavite thru mcx and daang hari. Okay daw ang takbo.
A friend drive it also around , okay naman sa kanya din maliban sa pag natingin sa rear mirror parang nahihilo daw sya. I am also practicing with it. okay naman sakin medyo concern din ako sa likod na glass pag gabi parang ang labo or kasi gabi nga. sabi pala ng binilihan ko, tint daw need ko na palitan yung sa windshield at likod.
Do i need to change anything or wait for 80kms milage? Wala naman kaming nakitang problem sa car, Maliban sa maraming gasgas na pinoproblema ko hahahaha
August 10th, 2016 02:59 PM #2688
When changing shocks, you should usually change in pairs because if not, the older one wears quicker and can also affect your alignment and tire wear. Check the tread level of the tires too.
Also check if the leather bits are worn out (steering wheel, shift knob). Unless you're fine with that of course. Getting the tint replaced will do good for your safety since I wouldn't advise driving with difficulty viewing the rear.
For the oil, check if it was FS or mineral. If mineral, have it replaced at 75k. If FS, you can go until 80k.
August 11th, 2016 10:43 AM #2689
ikaw pala yung kabalitaktakan ko sa altis club sa FB. hehehehe.
anyway, yung sa rear view mirror, try to use an aftermarket attachment. sa akin it works.
yung ingay sa compressor, baka sa compressor pulley bearing. mura lang yan (around 2.5k - 3k). paayos mo na lang bago magkaroon ng effect sa compressor mismo.
ilang km na sya ngayon? i advise replacing the fluids muna, including the oil.
- May 2016
- 40
August 13th, 2016 10:11 AM #2690Sir Jut703
ay ganon po ba. hmm pacheck ko kaya sa Delos Reyes Car care center palapala malapit samin hehe (Guys any review sa knila?) Thread level sabi sakin abutin pa atleast 1 yr , pantay sya walang pinakaiba mga gulong (ung kalbo wala)
Okay naman po yung steering wheels and knob, one thing i like is okay na okay yung interior nya mukang fresh pati amoy bago (baka pinadetail hehe) meron lng maliit na umitim sa may bandang gilid ng volume control the rest is very fresh. Bumili ako ng leather steering cover para added grip na din.at may lumang plastic na pinagsabitan ata ng dashcam naka double tape ang kapit masyado, paano tangalin po un?
Sir to be sure pina change oil na namin agad to FS since 68k milage pala un last PMS ayon sa records then 72k ko nabili.
Hindi po ako yun, ngbabalak palang po ako mg join dun heheh.
Ahh rear view mirror ang palitan ko ng aftermarket? hindi tint?
Yung sa ingay ng AC prang normal ata daw yun, kase naririnig ko din sa kasamahan ko sa office pag ka start nya ng bagong vios nya ganon din, prang ngchacharge ng aircon, nataas kaunti rpm, mas malakas lng ng kaunti ung sakin sa tunog.
72k na po. 68k un last PMS nun may ari dati.
lipat ko dito ung sinabi nyo sir sa detailing hehe.
a. done
b. not yet checked
c. TB? brakes po ba, front brakes was changed and backed drum brakes was cleaned.
d. Medyo bago pa daw, binugahan ng hangin then binalik
e. bago din, tinaktak lng namin lol
f. sabi nung ngbenta sakin last PM daw , kaso mukang buy and sell sya at hindi sya ng ng PMS kaya d ako sigurado. yung brake fluid lagpasan sa Max level indicator. dpat bawasan?
Fluid was sakto sa max level indicator.
and sakit sa ulo : ang daming gasgas minors and deep, may isang guhit pa na dent (kaya ngpost ako sa detailing ehehe)
hindi ko pa pla napipicturan ng maayos, will try later mgpicture pag umaraw na kaunti. kanina pa paulan ulan.
and its right above an electric motor....
BYD Philippines
