Results 2,581 to 2,590 of 3575
October 14th, 2015 09:06 AM #2581
^The fronts are heavier therefore the tyre will bulge more. That's normal. You may want to try also placing around 32-33psi instead of 30.
October 20th, 2015 11:11 AM #2582
the past month, my AC blower sometimes gets stuck up and gets noisy, na minsan kailangan ko pa pukpukin yung ilalim bago tumakbo.
may instances na naka on na yung blower ng auto AC pero walang hangin na lumalabas, until pukpukin ko yung ilalim ng gloves compartment.
i have tried having that checked with Ceejays, sinabi malamang blower nga.. nung nagtanong ako kung magkano, its around 6.5k....
meron pa kaya akong makukuhanan neto na mas mura?
October 20th, 2015 11:11 AM #2583
October 20th, 2015 11:31 AM #2584
- Jul 2015
- 73
October 20th, 2015 09:07 PM #2585I don't think blower ang may problema boss.. This problem is same with our Toyota Revo.. The culprit on this problem is the coil under the dashboard.. It is usually located under the passenger seat in front.. Minsan kailangan mo syang pukpukin para gumana.. You need to replace this which cost 3-4K.. Have it check sir, i had this problem also in my 99 corolla..
October 21st, 2015 09:19 AM #2586
- Jul 2015
- 25
November 2nd, 2015 10:00 AM #2587[QUOTE=vinj;2621931]Replaced the front shocks of my Gen 10.5 (55,000kms). KYB Excel G's cost P 3,250.00 per piece at Toyorama. I forgot how smooth the Altis can be. :D
Sir Vinj, shocks lang po ba pinalitan niyo at dapat may iba pang mga parts ang sinasabay kapag papalit ng shocks? At sa Toyorama niyo rin po ba pinalitan ng shocks?
Pasensya na po sa mga newbie questions. Salamat.
November 2nd, 2015 12:14 PM #2588
November 2nd, 2015 12:14 PM #2589
- Aug 2013
- 475
November 2nd, 2015 12:33 PM #2590try mo sir sa Cool drive. kahilera ng southville international school.
kung galing kang casimiro, papuntang CAA road, siya una mong makikita bago mag southville. nasa right side siya.
Palit ko sa AC blower ng pang 2nd gen vios P1.5K (surplus unit; kasama na labor sa installation), 2 years ago, hanggang ngayon ok pa din. baka same lang sila ng pang altis.
meron ding mga taiwan replacement.
Is it true na may recall ang yaris cross hev recently regarding sunroof issue? Lol.
China cars
