Results 181 to 190 of 240
February 27th, 2015 11:53 AM #181
February 27th, 2015 12:19 PM #182
naging sirain ang mazda magmula nung nabili ng ford. pa refund na lang yan at kumuha ng bagong Navarra o kaya Strada
February 27th, 2015 01:45 PM #183
Yup i will definitely go for a refund. I'm looking at the new Navarra already. Or baka sakali may new Hilux with better engine specs and 6 speed tranny or better.
February 27th, 2015 01:50 PM #184
Actually papasok na ko ng nlex mindanao avenue toll gate when it happened so napostponed yung trip ko. I used my 4x2 sorento instead the next day. As long as summer naman kayang-kaya naman ng sorento yung dirt road to my farm. Huwag lang mataon na rainy season at 4x4 talaga need ko dun.
- Jul 2014
- 162
June 26th, 2015 11:39 PM #186
Strike 4! Turbo hose ulit but I am definitely counting it as a repair of the same nature as the damahed turbo.
Lintek na lemon law strike 5 ang required.
June 27th, 2015 12:14 AM #187
Parang over boost yung turbo para sirain yung hose. Pwede bang palitan yung hose ng stainless tubing para di masira?
August 11th, 2015 07:27 PM #188
Had the 18 months/30000km pm done today at odo reading of 11130km. Di lang naman pala bt50 ko ang nagkasira ng turbo, madami daw kami. Stand out lang sa akin dahil naka-3 na hehehehe!
I remember someone ask before kung may auto-lock function. I decided to fiddle around with the manual again. Meron nga, although even the people at the casa say there is none. Switch ignition to engine ON, press door lock switch 3 times (make sure the lock activates each time), ignition switch OFF, press door lock 3 times, engine ON. Then engine OFF. There will be a confirmation chirp of the horn. You are now in "driver mode". Turn ignition to engine ON, press door lock 2 times, ignition OFF. Door locks are now set to lock at 10kph.
August 11th, 2015 09:51 PM #189
Yebo, naka strike 5 na ba mazda mo?
Curious ako if mag refund ang mazda. I hope everything is documented.
Sent from my Nexus 7 using Tapatalk 2
August 12th, 2015 11:28 AM #190
Strike 4 pa lang kung counted yung turbo hose. May print out ako ng record ng mga repairs.
Chinese EVs: Built to Not Last:wonder:
China cars
