Results 2,251 to 2,260 of 3483
- Feb 2015
- 12
March 31st, 2015 09:30 AM #2251Same concern. Pag bluetooth music hindi makita ung maps. Ang maririnig mo lang ung voice directions
- Nov 2014
- 87
April 1st, 2015 12:53 AM #2252Mga sir, ano po ba magandang air cleaner para sa fort? Pati brand, at saan po makakabili?
Tsikot Member Rank 1
- Jul 2009
- 4,090
- Jul 2009
- 4,090
April 4th, 2015 10:26 AM #2254
- Nov 2014
- 87
April 4th, 2015 10:47 PM #2256Mga sir pano nyo po napagana yung dvd nyo sa fort? Kc di po sya gumagana pag di nka hand break ano po ginawa nyo? San po kayo nagpagawa?
- Jul 2009
- 4,090
April 5th, 2015 02:26 AM #2257
- May 2011
- 108
April 5th, 2015 04:32 PM #2258Guys.. Standard 2 Din ba yung HU ng Fortuner?
Ayaw ko yung AVT naka install.. Planning to put a different HU.
Mabebenta kaya? 3 days old pa lang HU ko.
Kailangan pa ng panel or just change the HU?
April 6th, 2015 05:03 PM #2259
April 7th, 2015 08:21 AM #2260
Just so you guys know,
Modern EGR such as ours in fortuner have two functions; 1 is to induce exhaust gas during idle-light cruise and the 2nd which is most important is to dump overboost pressure. Blaking the pipe will create alot of overboost during at X time when ever you decelerate or the engine shift it's gear.
And there is a simple solution to eliminate the 1st function of the egr with by blocking the vacuum tube of the sensor valve which only cost less than 1 php.
Yes, the egr opens when vacuum is present.
Take a closer look at the top of the egr and you'll see two vacuum tube hence, it has 2 functions
I want to be clear that I'm mainly against just putting in water (deionized, distilled, or tap -...
Coolant...
