Page 205 of 256 FirstFirst ... 105155195201202203204205206207208209215255 ... LastLast
Results 2,041 to 2,050 of 2560
    Apr 2014
    #2041
    bossing... palagay ko ay hindi alternator o battery problem yan. palagay ko, engine problem yan.
    awww.. pinaoverhaul ko na kase ung makina e... tingin ko rin hindi alternator kasi malakas p ung kapit eh tas ung battery kabbili ko lng ... may alam b kayong mura at matinong talyer/casa d2 sa fairview? salamat ulit.....
    Apr 2014
    #2042
    Good PM,
    Mga Boss auto ko lancer EL ask ko lang if kapag nka aircon ako namamatayan ako ng makina lalong lalo na kapag medyo traffic at tanghaling tapat. ano kaya problema?
    #2043
    Hi to all. Patulong naman. See attached pic. May leak ako nakita sa area na yan. San kaya nanggagaling yan? Ty
    #2044
    Weird location for a leak. Nasa ilalim ng intake manifold.
    Could be oil from valve cover or head gasket na dumaloy down the curve of the manifold. Kapain mo ilalim ng manifold in that area kung basa.
    Ok pa ba aircon mo? Could also be compressor oil squirting from the fittings right beside it.
    #2045
    Yung sign of leak nasa left side po pala, just to clarify. Hindi siya sa side ng compressor ng a/c. Sorry for the confusion.
    #2046
    Nasilip ko lang kasi via the right side of the engine bay
    #2047
    newbie here. lancer itlog ex owner..
    Jun 2012
    #2048
    Mga bossing ask lang po...san po kaya magandang magpachek ng electrical ng itlog ko...mukang may grounded kasi..pag nag hazard at signal light ng kaliwa pati headlight at ilaw s gauges ngbi blink din xa...mga magkano kaya abutin pa chek nun...on tight budget po kasi kya kelangan ko muna malaman kung magkano bago ipagawa...nwey taga paranaque po ako...tnx po
    Dec 2013
    #2049
    Magtatanong lang po ako kung ignition coil symptom na po ba ang problema ko. Habang nagddrive po kc ako cguro mag 2hours na biglang namatay ang makina with aircon po pala ako nun while driving. Tapos checkup ko engine kung overheat or anything else, pero ok nman ang tubig and temp gauge, sa tingin ko hindi sya overheating. Nag start ulit ako ng kotse, then ok na ulit sya, this time without aircon, mga after 15 minutes, tumabi muna ako na hindi inioff ang makina, then ini-on ko ang aircon, checkup ko up ko ulit ang makina kung ok, sa tingin ko ok naman, wla overheat or anything. Then when i'am about to go ahead 1st gear p lng nag stop ulit ang makina. Then about couple of minutes nag start ulit ako ng kotse, ok n ulit sya, this time without aircon. Is there any problem with my aircon, electrical or anything... sabi ng napagtanungan ko ay ignition coil daw, umaagaw ng kuryente ang aircon, then pag maiinit na ang coil ay ititirik daw ako nun, may katotohan po kaya un. maraming salamat po.
    #2050
    Quote Originally Posted by Hybrider View Post
    yes. possible ignition coil problem.
