Results 1,341 to 1,350 of 2721
December 19th, 2013 07:40 PM #1341
- Jun 2007
- 187
December 19th, 2013 09:19 PM #1342
- Jun 2013
- 159
December 20th, 2013 01:23 AM #1343Thanks for the advice guys, inisip ko na nga rin tanggalin totally ung accessories then bring it to the dealer where I originally bought the car to avail the warranty, kaso nasa Cabanatuan pa kasi yun. Try ko rin unplug yung battery hoping it would reset the ECU, nabasa ko rin kasi sa ibang forum yung mga nag-flash sa panel though not particularly yung AFS then after nag-adjust yung ECU after 2 days of driving bumalik na sa normal yung car. Somehow wala naman problem yung door sill sa 2.0 variant, sa 2.5 lang ata kasi mas marami itong features.
- Jun 2007
- 187
December 20th, 2013 02:22 AM #1344
- Jun 2010
- 452
December 20th, 2013 09:47 AM #1345
- Jun 2007
- 187
December 20th, 2013 10:26 PM #1346Found this guide on the led scuff plates installation on Mazda247 forums. This should take the guessing game out of the installation of the scuff plates.
https://dl.dropboxusercontent.com/u/...STALLATION.pdf
Hope it helps future installations. Just print it out and bring it to installers.
December 21st, 2013 07:22 AM #1347
December 21st, 2013 08:06 AM #1348
- Jun 2013
- 159
December 21st, 2013 03:40 PM #1349Yup, there's no problem with the 2.0, it's the 2.5 that we need to be careful since a slight change in voltage will affect the other tech features of the unit. I also disconnected the battery for about 15 minutes (though germs said dont disconnect the battery which I read only after nadis-connect ko na) luckily it did not disable my i-stop but still no luck with the flashing AFS. Am going to contact my dealer where I bought the unit but my next problem is removing the LED door sill without damaging (scratching the car) and bending the accessory sayang naman 3.6k din yun :kick:
December 21st, 2013 05:36 PM #1350
Why not leave it there and just disconnect the connections? At least it will not get damaged and when somebody finds a solution it will only take you to reconnect it to the proper/correct source. Have you tried reading and doing the procedures posted by LRTan? Maybe worth a try.
