Results 21 to 30 of 152
- Jun 2009
- 226
May 5th, 2011 05:14 PM #21
Tsikot Member Rank 4
- 2,719
May 5th, 2011 05:47 PM #22^ or you can try "F:\Map" on a nuvi 1300
btw ... a new 1300 will not have a file gmapsupp.img on it ... the first time Mapsource is used to install a map, it will create the directory called "Map" on the unit and wites the gmapsupp.img file on it
May 5th, 2011 07:00 PM #23
*desertfox615 and kinyo;
Thanks for the tip. I copied the gmapsupp.img file into my device but still can't get a satellite reading. Pls bear w/ me as I ask this: do I also have to copy the mapsource file into my Nuvi? I downloaded and ran it and it's now in the PC. But when I try to access it through All Programs > OSM-PH Garmin maps > a drop down menu of "Uninstall" (with a crossed out icon) and "Website" appears. Is this the end result of the installation?
Btw, kinyo my OS is XP.
Thanks again.
- 2,719
May 5th, 2011 07:18 PM #24*JackFlash ... i think you only installed the OSM map for Mapsource ... not Mapsource itself ... to run Mapsource, you should be clicking on Start->Programs->Garmin->Mapsource
if indeed you already installed Mapsource and as you say running, what version is it?
Mapsource works on XP or Win7. It is installed only on the PC, not on the nuvi.
May 6th, 2011 12:55 AM #25
kindly check out this link: http://roadguide.ph/forums/showthread.php?t=1526... this will help you get started.
May 6th, 2011 10:40 AM #26
May 24th, 2011 11:24 AM #27
How does one get the updates on OSM maps? I've downloaded a map already but wondering if there are updates. Some of the streets and directions in the one I downloaded are no longer correct. Been searching through the OSM site but can't find any links on uploads. Thanks.
- Jun 2009
- 226
May 24th, 2011 12:05 PM #28http://esambale.wikispaces.com/osmphil_garmin
last update of gmapsupp.img is May 23, 2011
May 24th, 2011 12:33 PM #29
Thanks. Which link do I click on...
- executable file for Mapsource
- installer for Mac RoadTrip (data as of April 15, 2011)
- compressed gmapsupp.img
- README.txt
- Routability debugging report
- Last update: There are problems with the macroadtrip installer. The latest working map available for macroadtrip here is April 15, 2011. The compressed gmapsupp.img and mapsource is unaffected by this issue.
May 24th, 2011 12:34 PM #30
- README.txt
China's EV industry concerns. Here's what we know CNBC Television
China cars
