Results 1,061 to 1,070 of 2560
- May 2009
- 10
September 6th, 2010 02:42 PM #1062*Libme same pla tyo eggie..glxi A/T din ung skin..Bro kmusta nman ung eggie mo wla ka pa ba major,major na problem dyan..Matanung lang..Ako kc nagpalit na ng servo mabigat yung gastos dun full assembly pinalitan ko..glad to hear from u soon..Tnx.
- Jul 2008
- 5
September 6th, 2010 03:03 PM #1063Hi to all fellow itloggers!
Tanong lang po mga bro, dami kasi sira sa itlog ko (95 glx A/T), 1) Sira yung transmission ko, pag naka gear, 3rd gear lang takbo nya (matagal magpick up ng speed, and 60-70kph lang fastest na takbo nya), and the indicator lights are off (yung sa dashboard na ilaw, di nakailaw if naka neutral, reverse, or drive). Overhaul na ba to or may maliit lang na kelangan ayusin? 2) I get a whirring sound from the front left wheel the faster I move. pinagawa ko na, bearing, tire rod, palit brakes, andun pa din, any suggestions sirs? Hope you guys can assist, thanks!
September 6th, 2010 11:12 PM #1064
- May 2009
- 10
September 7th, 2010 11:10 AM #1065
- Aug 2010
- 2
September 7th, 2010 03:45 PM #1066mga sir itlog ko glxi 95 model ayos 3rd owner na ako, new bie lang po ako ... tama po ba yung ginawa ko after kong binili ung itlog pinachange oil, change timing belt, tuneup, change spark plug, change spark plug cable...
- May 2009
- 10
September 7th, 2010 06:29 PM #1067
- Jul 2010
- 43
September 8th, 2010 09:52 AM #1068
- Jul 2010
- 43
September 8th, 2010 09:56 AM #1069palitan mo na ng bago. Punta ka ng banawe. Tanong mo si Kingpin 8.5k ang tranny then labor aroung 2.5k. Wag mo na pa overhaul masmaganda palitan mo ng surplus. Anyways may 3 months warranty sa kanila.
YUng whirring sound baka sa axle mo yun. machecheck na rin yan pagpinagawa mo yung tranny mo.
- Jul 2010
- 43
September 8th, 2010 09:58 AM #1070
Coolant...
