Results 981 to 990 of 1770
October 16th, 2009 11:20 PM #981other wise lilipat ang ibang consumer.
- Aug 2009
- 349
October 16th, 2009 11:38 PM #982Pasensya napo ! out sa topic dito. but nakita ko kasi dati dito yung marunong maglinis ng or espicillty nilang maglinis ng mga ibat ibang aircon. Ppaki PM naman po ako at may tanong lang ako about sa home aircon. hehehe.. thanks!
October 18th, 2009 10:14 AM #983
with the current high price ng crosswind now, I can say na maswerte pa pala ako. although mas medyo advance mga features nya now (e.g projector lamps).... I own 2008 xuv, that time mura pa yon compare sa presyo now, considering na halos the same lang naman yung vehicle. halos walang pinag iba when it comes to engine, suspension, body....yung price difference nya for me parang hindi compensated yung mga dinagdag na festures nya....so maswerte pa rin tayong mga naka 08 model.:peace:
October 21st, 2009 11:50 PM #984
XUV07 :30500km 2 years and 3 mos na.
so far wala pang major replacement nangyari x wind ko only clutch overhaul nag crack daw rubber at 20k km at 25k km twice nag overhaul.
wala pa akong na notice either sa radiator and exhaust.
ang problema sakin ngaun ay ang mugs ko na goodyear sa mga XUV models kasi UNEVEN TIRE WEAR at parang nag wabble at 60kph ang ingay2x...
sabi ng isuzu GOODYEAr tires ng crosswind daw mostly the same case as mine.. they recoment MICHELNE,DUNLOP or BRIGEsTNE.. may na notice ba kayo sa gulong nyo na GoodYear XUV owners??
October 22nd, 2009 11:34 AM #985
Walang kasalanan ang gulong sa uneven tire wear at wabble...nasa propper alignment, camber or caster alignment ng vehicle yan. I also experinced this to my XUV 08, nung pinacheck ko sa servitek they found out na may camber alignment problem. nung nagawa pina rotate ko 4 na gulong to check kung na correct yung problem, ayun, pumantay tire wear nya, nawala din wabble.
October 22nd, 2009 10:26 PM #986
ask ko lang if magkano price nung michelin? na pang sportivo.. ganda kasi e..
- Oct 2009
- 7
October 22nd, 2009 10:48 PM #987ei guys kmusta? tanong ko lng mga pare matagal ba tlga magdeliver ang isuzu? mag 3 weeks na kc nmin inaantay ung unit na 2010 sportivo..nung bumili kmi sa ibang brand dati less than 1 week nakuha agad nmin...ask ko narin samga naka 2010 sportivo kung kamusta naman ang performance ng sportivo nyo? satisfied ba?
October 23rd, 2009 10:45 AM #988
pero kahit na ito pa rin number 1 sa autofocus car of the year AUV category. Check this out.......http://autofocus.com.ph/vresults.php
October 23rd, 2009 11:11 AM #989
Ang mahal na naman ng diesel! bagay na bagay sa mga may Crosswind
Ang sarap palaging i-full tank ng 55 liters kasi parang hindi nababawasan :2thumbsup:
- Dec 2008
- 16
When changing your ride's serpentine belt, is it a must to replace the tensioner too?
Drive belt engine
