Results 1 to 10 of 11
- Oct 2008
- 380
August 20th, 2011 04:28 PM #1will replacing the antenna with a higher dbi increase the coverage range of my router? im planing to replace mine(5dbi) with a higher one either a 7 or 9 since i want to increase its reach. gsto ko sana umabot hangan sa mga kwarto namin
thnx
August 20th, 2011 04:41 PM #2
Changing the antenna will only marginally increase the range.
If your current wifi router is only a "G", upgrading the entire router to a "N" wifi router will increase the range.
Alternative is to "bridge" using another wifi router or wifi extender. Or install another wifi router in your room and have it cabled and configured to your first router working as gateway for the 2nd router (in your room).
August 20th, 2011 06:55 PM #3
Tsikot Member Rank 4
- Jun 2006
- 2,605
August 20th, 2011 07:22 PM #4I used a 9dbi high gain antenna from cdrking. Useless. I changed to a N router and it did increase my range. Even if your house is not big, constrcution affects wireless signal. Cement, steel, microwave ovens, cordless phones and maybe even tv sets can affect your signal.
GH, how do you bridge wireless routers? does it have to be the same brand? I'm asking cause I have weak signal at some areas of the 2nd floor. I dont want to run cabling thru the windows.
August 20th, 2011 08:49 PM #6
The newer routers have a bridge setting. No need to have the same brand.
Older routers without bridge setting, I think they can be used as a wifi bridge but you have to manually set the configurations. I haven't tried it though.
BTW, wireless bridging will cut down in half the max data speed in the bridged wifi area. It won't affect you if you are just surfing but if you are transferring files, you will definitely feel the speed difference.
Alternative, powerline networking then plug in a wifi router. A bit more expensive because of the cost of powerline network devices.Last edited by ghosthunter; August 20th, 2011 at 08:52 PM.
- Oct 2008
- 380
August 21st, 2011 07:40 AM #7actually both are N routers . my old one is tplinkwr740n. nkakasagap sa kwarto and di naman na disconect. my new one a tenda3g611r+. kaya ako nag palit, kasi nasira na yong tplink. napansin ko lang di ako makasagap sa kwarto with tenda. e according to specs both use 5db antena. kaya i was thinking of replacing it with a 9db antenna from cdrking.
- Oct 2008
- 380
August 21st, 2011 07:44 AM #8
August 21st, 2011 02:13 PM #9
You might want to try making a DIY parabolic dish to amplify the wifi signal in a particular direction.
GUIDES:
Parabolic Templat
DIY WIFI Antenna Reception Booster
- Oct 2008
- 380
My thoughts: Resale value is really about perception, and right now the perception is that a...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
