Results 1 to 11 of 11
    Oct 2008
    will replacing the antenna with a higher dbi increase the coverage range of my router? im planing to replace mine(5dbi) with a higher one either a 7 or 9 since i want to increase its reach. gsto ko sana umabot hangan sa mga kwarto namin
    thnx
    Quote Originally Posted by african888 View Post
    thnx
    Changing the antenna will only marginally increase the range.
    If your current wifi router is only a "G", upgrading the entire router to a "N" wifi router will increase the range.
    Alternative is to "bridge" using another wifi router or wifi extender. Or install another wifi router in your room and have it cabled and configured to your first router working as gateway for the 2nd router (in your room).
    Aug 2005
    thnx
    gaano ba kalayo? or rather, gaano kalaki house nyo? hehehehe
    para dumoble ang range, dapat mas malakas by 6 db ang replacement antenna.
    Jun 2006
    I used a 9dbi high gain antenna from cdrking. Useless. I changed to a N router and it did increase my range. Even if your house is not big, constrcution affects wireless signal. Cement, steel, microwave ovens, cordless phones and maybe even tv sets can affect your signal.
    GH, how do you bridge wireless routers? does it have to be the same brand? I'm asking cause I have weak signal at some areas of the 2nd floor. I dont want to run cabling thru the windows.
    sa settings lang pag bridge
    Quote Originally Posted by userfriendly View Post
    The newer routers have a bridge setting. No need to have the same brand.
    Older routers without bridge setting, I think they can be used as a wifi bridge but you have to manually set the configurations. I haven't tried it though.
    BTW, wireless bridging will cut down in half the max data speed in the bridged wifi area. It won't affect you if you are just surfing but if you are transferring files, you will definitely feel the speed difference.
    Alternative, powerline networking then plug in a wifi router. A bit more expensive because of the cost of powerline network devices.
    Oct 2008
    actually both are N routers . my old one is tplinkwr740n. nkakasagap sa kwarto and di naman na disconect. my new one a tenda3g611r+. kaya ako nag palit, kasi nasira na yong tplink. napansin ko lang di ako makasagap sa kwarto with tenda. e according to specs both use 5db antena. kaya i was thinking of replacing it with a 9db antenna from cdrking.
    Oct 2008
    siguro mga 10meters po with wooden and concrete walls as partition. so para dumoble range e hanap ako ng 11db na antena?
    You might want to try making a DIY parabolic dish to amplify the wifi signal in a particular direction.
    GUIDES:
    Parabolic Templat
    DIY WIFI Antenna Reception Booster
    Oct 2008
    hhmm interesting... something to do this long weekend
    Sep 2011
    hi thanks for your information i am new to this forum
wireless router antena
