What's a good brand and model? Para pwede ba mag print from smart phone ng mga emails, etc.
Am using hp3525, print, scan, copy. Does what its supposed to do. Can print wirelessly to it from tablet, phone, laptop. Even if youre outside its wifi network. Cheaper ink as well.
I am using HP bro, at home. Forgot the model- but this comes with scanner...
Everything's tied to our wireless router.
Two desktops on wireless, five laptops on wireless,- no issue.
I have not tried printing from a handphone, though....
28.3K _/_/_/_/_/:santa:_/_/_/_/_/
I have an HP P1102w (monochrome) laser printer. Supports printing from iOS devices, among others.
i don't use a wireless printer per se.
but bought a router with print server, and attach the printer to the print server.
another option is to just attach the printer to the router, share it via network and print from the WLAN.
Just to add, if you have iOS devices and you wish to print from them, you should look for a printer or printer server that supports AirPrint.
Or you'll go insane.
Thanks. So HP is the way to go. Wala ba ibang brand? Are newer HP models uses the same ink cartridge across models? Or should it be another basis when buying a printer? Ano model yun murang original ink cartridge.
Im using Samsung Wireless Laser Printer. it can print from iPhone, iPad, Macbook, My relative's androids and Windows laptop.
Good! Hanap ako Sa weekend? Saan maganda bumili? Yun Maraming choices
That's the going insane part. Let me explain... Imagine yourself holding your iPad/iPhone and standing directly in front of the printer. But since the printer you have doesn't support AirPrint, you can't do anything. Firing up a PC is just ludicrous if you just want a frickin' hard copy of something that's already on your palm. Imagine that someone to be your lolo or lola or mother-in-law, etc.
I mean, things like that should no longer happen at this day and age. Things should just work.
So, if you have or plan to own an iOS device, you'll be doing yourself a big favor by getting a printer that natively supports AirPrint.
I had the HP 3510 printer/scanner with wifi. It already has relatively cheap cartridges (HP Ink Advantage, around 400 per cartridge, different cartridge for black and colored) but it's still quite costly - I replaced black cartridges every other month, and colored cartridges every 3-4 months.
Recently replaced it with Epson L355 continuous ink. My siblings print their college papers in full color, halos wala pang bawas sa ink tank. Baka graduate na sila di pa ubos yung ink. [emoji12]
Same wifi functionality and connectivity, printer and scanner na rin.
I am using Brother MFC-J625DW that supports AirPrint/Scanner/Printer/Auto Loading Feeder/FAX for 4 years na. So far no problem whatsoever.
I have installed a 3rd party ink cartridge and it can print 1 to sawa hehehe.
