Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Jul 2003
    namana ko yung laptop ng kapatid ko. compaq evo410c. pentium 3 lang siya. gusto ko sana bumili ng wireless adapter para makasurf ako using free wifi sa area namin.
    nag tingin ako and d-link and linksys yung usual brand costing around 2K.
    sa palagay niyo, anu mas ok bilhin dun sa dalawa??? kaya ba ito ng system ng laptop (256 ata yung ram????)
    basic points to consider in buying wireless adapters???
    other suggestions (like other brands etc.)
    wala pa ako budget for a new laptop kaya adapter muna.
    tnx!!!
    Pwedeng makisakay sa thread mo hehe...
    When people say kailangan i-"repack" yung battery, what does it mean? Papalitan yung cells sa loob? On average, how much to?
    Thinking of getting a laptop kasi, and madalas pang 2nd hand medyo short na ang battery life.
    wireless g pcmcia card
    Quote Originally Posted by theveed View Post
    papi...sa ashcreek sa gh alam ko nag rerepack sila dun for a good price..good quality rin.
    Dec 2003
    either brand is ok
    Paps, repacking involves changing the battery cells... last time I inquire nasa 450 per cell... but that was a few months ago na...
    Jul 2003
    ok tnx!!! will probably go for linksys since yun ata gamit nung office na may wifi. but will inquire other brands din.
    battery is ok pa naman. :D
    May 2005
    Quote Originally Posted by fourtheboys96 View Post
    Just dont get Asus adapter. MY notebook is an Asus (with wifi) and my officemate has an Asus adapter, connectivity to our wifi drops every now and then. Others using different brands of notebooks are ok. I think it has something to do with the driver of the wifi adapter.Btw, our router is a Linksys.
    I bought a Linksys Wireless G PCMCIA adapter for my old Toshiba laptop. Mahina ang pickup ng signal nung Linksys. Hina ng signal if I try to connect sa 2nd floor bedroom (access point ko nasa living room).
    I suggest you bring your notebook to test out the signal strength when you want to buy a wireless adapter card. You can choose between Linksys, DLink, Aztech, Belkin, or Netgear. Try to find one with an antenna, I think it will be able to pickup wireless signals much better.
    tnx!!!
    pwede na yung d-link bro. it will work sa laptop mo.
    Jun 2006
    Quote Originally Posted by fireblade View Post
    Turn-off Wireless Zero Configuration.
    START->RUN "services.msc" then "stop" Wireless Zero...
    That should fix it.
    I'll been using "leadtek" for almost 2years now..in my old laptop. it never fails me in any hotspot I visited
    May 2005
    Quote Originally Posted by Horsepower View Post
    That should fix it.
    Thanks sir, just tried it now and hope it works in my office tomorrow.
    Jul 2006
    You can buy any Taiwan brand wireless pcmcia 54g adapter. Much cheaper than the branded versions. Mas makakatipid ka pa.
    The branded & taiwan adapters basically use the same chipsets..
    for example... a linksys usb wireless adapter has the same chipset used by an edimax PCI wireless adapter - RaLink.
    Try buying edimax. Mas sulit 1 thousand lang compared sa branded above na 2k-2,500 ang prices.
    Rule of thumb is buy a cheap adapter but buy the branded router. That's the practical, cost-saving solution.
    May 2005
    That should fix it.
    Geeez, still it didnt work when I tried it in the office. Keeps on dropping off. Here in the house Im also using a Linksys router and it never dropped.
    Do you have any other wireless devices in the vicinity? Also, older cordless phones can interfere with the wireless device.
    Here at home, the wireless autosensor that allows our washing machine and drier to "talk" to each other interferes with the pc wireless reception. It's not quite strong enough to make the pc wireless signal drop off. But, it is slowed down quite a bit.
    Jun 2006
    Given those variables, the problem is with the router (and/or its signal) in your office.
    Jul 2006
    Pekto is correct. change the channel of your router. Recommended are 1, 6 & 11...
    FYI. Alam nyo ba na ang meralco ginagamit ang 2.4Ghz range??? And ang Smart Bro uses the 5Ghz range??? Just got this information from a reliable source....
    Jun 2006
    5GHz? ahhh, kaya pala yung isang laptop ko nakakarecieve ng Smart Brokeback signal. ehehehehehe.
    hiram nga ako ng acct :D
    Jul 2006
    Horsepower - to be more detailed, Smart Bro uses 802.11a technology which means maganda yang wireless card mo sa laptop baka a/b/g kaya or a/g.
    Pero d ka makakakuha kasi may register IP addresses at MACs ang mga antenna e... Pero baka magawa mo share mo naman ang discoveries mo
wireless adapters
