Results 11 to 20 of 24
August 14th, 2006 06:23 PM #11
- 3,754
August 14th, 2006 06:44 PM #12I'll been using "leadtek" for almost 2years now..in my old laptop. it never fails me in any hotspot I visited
August 14th, 2006 10:59 PM #13
August 15th, 2006 07:10 PM #14
You can buy any Taiwan brand wireless pcmcia 54g adapter. Much cheaper than the branded versions. Mas makakatipid ka pa.
The branded & taiwan adapters basically use the same chipsets..
for example... a linksys usb wireless adapter has the same chipset used by an edimax PCI wireless adapter - RaLink.
Try buying edimax. Mas sulit 1 thousand lang compared sa branded above na 2k-2,500 ang prices.
Rule of thumb is buy a cheap adapter but buy the branded router. That's the practical, cost-saving solution.
August 15th, 2006 11:09 PM #15
August 16th, 2006 01:04 AM #16
Do you have any other wireless devices in the vicinity? Also, older cordless phones can interfere with the wireless device.
Here at home, the wireless autosensor that allows our washing machine and drier to "talk" to each other interferes with the pc wireless reception. It's not quite strong enough to make the pc wireless signal drop off. But, it is slowed down quite a bit.Last edited by Jun aka Pekto; August 16th, 2006 at 01:06 AM.
August 16th, 2006 01:50 AM #17
August 16th, 2006 02:54 AM #18
Pekto is correct. change the channel of your router. Recommended are 1, 6 & 11...
FYI. Alam nyo ba na ang meralco ginagamit ang 2.4Ghz range??? And ang Smart Bro uses the 5Ghz range??? Just got this information from a reliable source....
August 16th, 2006 03:16 AM #19
5GHz? ahhh, kaya pala yung isang laptop ko nakakarecieve ng Smart Brokeback signal. ehehehehehe.
hiram nga ako ng acct :D
August 16th, 2006 03:33 AM #20
Horsepower - to be more detailed, Smart Bro uses 802.11a technology which means maganda yang wireless card mo sa laptop baka a/b/g kaya or a/g.
Pero d ka makakakuha kasi may register IP addresses at MACs ang mga antenna e... Pero baka magawa mo share mo naman ang discoveries mo
Thank you!
