i already did tried to configured a couple of this in vista with regards to network file and printer sharing
To ensure that File and Printer Sharing is installed in Microsoft® Windows Vista(tm), perform the following steps:
1. Click Start.
2. Click Network on the right-hand column of the Start menu.
The Network window opens.
3. Click Network and Sharing Center on the navigation bar across the upper part of the window.
The Network and Sharing Center window opens.
4. Click Manage Network Connections under Tasks in the upper-left hand area.
The Network connection window opens.
5. Right-click Local Area Connection or Wireless Network Connection, then click Properties.
The User Account Control window appears.
6. Click Continue.
The Network Connection Properties window opens.
7. Ensure that the check box to the left of File and Printer Sharing is checked.
8. When File and Printer Sharing is not listed, Click Install.
The Select Network Feature Type window opens.
9. Click Service.
10. Click Add.
The Select Network Service window opens.
11. Select File and Printer Sharing, then click OK.
The Select Network Service and the Select Network Feature Type window closes.
12. Click Close or OK.
The Network Connection Properties window closes.
To ensure that Client for Microsoft Networks is enabled in the Microsoft® Windows Vista(tm) operating system, perform the following steps:
1. Click the Start button, and then click Network on the right-hand column of the Start menu.
2. Click Network and Sharing Center on the navigation bar across the upper part of the window.
3. Click Manage Network Connections under Tasks in the upper-left hand area.
4. Right-click Local Area Connection or Wireless Network Connection, then click Properties.
5. Click Continue.
The Network Connection Properties window appears.
6. Ensure that the check box to the left of Client for Microsoft Networks is checked.
7. When Client for Microsoft Networks is not listed, Click Install.
8. Click Client.
9. Click Add.
The Select Network Client window opens.
10. Click Client for Microsoft Networks, and then click OK.
The Select Network Client window and the Select Network Feature Type window closes.
11. Click Close or OK.
eto talaga malufet sa lahat eh at siguro makakaresolve niyan..
Enable the Guest Account in Microsoft® Windows Vista(tm)
1. Click the Start button, type command in the Start Search box.
2. Right-click Command Prompt in the list of Programs, then click Run as Administrator.
Note:
The User Account Control window may appear, if so click Continue.
3. Type net user guest /active:yes, then press the <Enter> key.
The message Command Completed Successfully appears.
4. Type exit, then press the <Enter> key.
The command window closes.
NOTE: DO THIS IN ALL COMPUTERS ^
HTH
nahirapan ako kalkalin mga cheatsheets ko dito sa vista ampepe..
