Results 1 to 20 of 212
    Punta ka Binondo yun joven brand walapNg 2k
    Single Lang yan ha hinde multi point
    Sent from my iPad using Tsikot Car Forums
    #retzing
    Oct 2008
    #retzing
    thanks sa reply sir shadow, san po sa binondo and any shop in particular?
    Quote Originally Posted by african888 View Post
    T Alonzo street corner soler tapat ng arranque market. Isa Sa hardware doom ako nakabili
    Posted via Tsikot Mobile App
    I want to buy a Panasonic. Where's it best to buy (lots of choices and good price) The last time I bought was 20 yrs ago at MC Home depot ata in Ortigas
    robinsons, shoomart...
    these buys usually now come with "free installation". they will install the thing for you, "free of charge". but you will pay (thru the nose) for the accessories they will use in the installation.
    i suspect, the manufacturer, like car makers, practice price control across the metro.
    Mar 2004
    Try Lazada ...
    Jan 2010
    And just like air-con installers, they will insist you buy their cheapo circuit breaker even if your house already has one.
    I would suggest buying from ACE Hardware or Handyman as they have direct contact with the distributor in case the unit goes kaput. Their stocks tend to be newer too (especially at the malls) and there likely is a 0% installment option if you're buying using a credit card.
    Just be mindful that the installers need to be watched over, in case they screw up your tiles or the drainage in your shower. If your shower area already has provisions for a wall outlet, you'll most likely not need to get the circuit breaker they are bringing with them. They will insist that it isn't safe without another circuit breaker, but that's BS. My analogy for it is that it's like wearing a second condom on top of another.
    Jan 2009
    We have a dedicated circuit breaker for the shower heaters. They are both centrally-located, meaning, there are no breakers in the bathroom... just the 20A grounded outlet (same or similar to the common A/C outlet).
    The water heater itself did not come with any plugs... just the power and ground wires. I provided the installer the 3-pronged 20A plugs. It's been over 12 years and so far so good.
    Feb 2024
    As long as there is already a dedicated (not shared) circuit breaker for the water heater then yes, no need for another circuit breaker.
    Oct 2008
    shadow,
    meron din bang ibang brands na available sa binondo? am looking at champs sana, baka mas mura don kaysa sa Ace/Handyman.
    thanks
    Oct 2008
    finally naka bili na ako panasonic 3.5kw, single point. sa mc home depot ako bumili... hopefully ma install na tomorrow , medyo malamig na ngyon pag umaga
Water heater for Showers
