Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
    #21
    Wala pa bro. Pwede ba i-series ung uv light sa existing set up?
    Sent from my SM-T865 using Tsikot Forums mobile app
    Yup pwede i-series. Just have to make sure the fittings are the same size. Yung amin is 3 stage plus UV from the same manufacturer kaya same lang ng fittings.
    Meron RO filtration di na raw kelangan ng UV pero masama naman daw sa katawan
    Thanks bro. Will have to ask the installer kung may available na UV light.
    #23
    I installed water filters na lang in my units para wala ng hakot2 pa. Just have to replace every 5 months and cost around 2.5K. Worth the hassle naman.Attachment 37535
    so that's 500 bucks a month...
    our nawasa bill is 1000 pesos a month.
    if we switch back to poso...
    our electric bill will remain the same, whichever source we go for.
    hmmm...
    Oct 2008
    #24
    question lang po, mas makatipid ba sa kuryente if we will use a water dispenser versus old school way na :
    a. hot water, every morning init kami using a electric kettle then lagay sa thermos. one iniit is good for the day na po ito;
    b. cold water, lagay ng lukewarm water sa ref then pag gusto inom ng cold, get pitcher sa ref then pour sa baso.
    Nov 2019
    #25
    If I were to ask at may budget, better to buy branded and tested ones like GE or Panasonic if meron. I bought kyowa, worth 8k din. Akala ko matibay due to price, 6 months lang bumigay compressor, pinapa warranty ko. Reason bakit bumigay is hindi daw talag matubay compressor mostly ng local brands. Bibigay talaga lalo na if lagi g may low or high voltage sa electric lines nyo. Kinabit ko nalang sa AVR ang unit, ok naman so far. Mag 2 yrs yung unit next year July, sana AVR lang talaga solution para magtagal ang compressor nito.
    Jan 2009
    #26
    Quote Originally Posted by african888 View Post
    Yes, mas matipid yung suggestion mo. But depende pa rin.... Kung maya-maya bukas ng ref to get a glass of water, it will consume more electricity. And then you will have to replenish the water in the pitcher/jug multiple times a day and syempre, palalamigin ng ref yan.
    In reality, zero-sum yan.
    FWIW, you are buying a water dispenser for the convenience. That's it. Just replace the 5-gallon jug every couple of days and you can have instant hot/cold water anytime.
    What I do is, I have a timer setup on both the Hot and Cold circuits. Yung Hot water, available lang from 6:00-8:30am (breakfast time) while the Cold water is available only from 7:00am-9:00pm. Anytime during the day kung kailangan ko mag-init ng tubig to drink coffee (minsan lang), meron akong routine to turn on the Hot water for 20 minutes only, then patay sya ulit until the following morning.
    Quote Originally Posted by carxynogen View Post
    4 water dispensers in our compound.... all are local brands.. Kyowa, Camel, American Heritage (or Home), etc. Never bumigay compressors. May isa lang, medyo natunaw connector ng heater (assembly defect).
    In other words, they're pretty reliable.
    Pero, sabi mo nga... ang problem sa inyo is electricity. Any appliance won't last long kung unstable electricity supply mo.
    Oct 2008
    #27
    thanks for the reply. additional question, if buy a water dispenser, need ba ng separate na outlet for that? or can i plug it in together sa outlet with Refrigerator?
    #28
    i have more expensive GE at home.
    workplace has cheaper generic.
    na-una pang nasira yung GE ko.
    i think the lesson is,
    buying generic is not a bad gamble.
    Jan 2009
    #29
    Typically, no. You will have to check the specifications of your water dispenser.
    I see models ranging from approx. 300W to 700W.
    The compressor side usually consumes 65-85W, give or take. On the Hot side, however, those that are "fast-heat" or "fast-boil" usually consumes 400-550W.
    The one we use at home (Camel), takes a while to heat (appox. 20 mins) because it only has a 190W low-power heater.
    Nov 2019
    #30
    Solid Panasonic ref namin, running for almost 15 yrs na. So solid yung compressor ng panasonic even on an unstable electric voltage. That’s the reality sa place namin, need to find solid product para magtagal sa ganitong unstable electricity. Yung Carrier AC namin, hindi nagtagal ng 1 yr. Nag activate daw failsafe mechanism ng controller kaya need reset. Every visit ng technician just to reset the controller is too much. Nag give-up na ako sa Carrier AC namin. Good to know working pa rin tong mga products if stable ang electricity. Yung GE AC namin, good pa, running 2 yrs na, binili ko as 2nd hand from in-laws.
    Disappointed lang ako sa Compressor ng Kyowa dispenser namin.
    Jan 2009
    #31
    Again, the root cause is your bad electricity. Don't put all the blame on budget-oriented appliances. If everyone has money for a Panasonic, or a Sub-Zero, or a Thermador, or [put whatever brand name you wish], there's still no assurances that they will last in an electrically-hostile environment. All appliances are designed to work within certain tolerances.... some, a degree or so more tolerant than others.
    It's good that your Panasonic can take your bad electricity, but for the millions of consumers, their Kyowas or Hanabishi, or American Home units work equally just fine in their own environment.
    #32
    mukhang heavy duty naman itong nabili ni wifey na Bostonbay bottom loading water dispenser.
    pag nagtagal ng 2 yrs ito ay sulit na sya.
Water dispenser thread
