Results 21 to 40 of 49
    Feb 2003
    #21
    While you're at it maybe add a small fan and piping for venting ozone.
    No need just hold your breath and remove the cover and leave it there for a few minutes and it will be purged eventually. Actually the Ozone ang mas effective for those area na not reached by the UVC raylights.. Now if Ozone is really you don't want meron nabibili na UVC lamp na not Ozone generating. To prove the effectivity easy lang naman, just need min. 7days...2 piece of bread one treated with UVC lamp and the other not...dapat magrows ng maraming molds yun not treated. If both nag grow ng same amount ng molds then...japeyks yun lamp.
    I chose nga ung ozone generating for extra disinfecting power nya.
    #22
    Yes the ozone penetrates the porous materials in the box and disinfects them. Meant venting it after the disinfection is done. This could be done via a small fan inside the pipe and a removable end cap.
    Feb 2003
    #23
    Heto ganito yun saken....twice as big lang nun size nya...mga 2K all in ang capital ko Oks na din value netong sa Lazada. .
    DAIMARU UV STERILIZATION BOX with Timer Control Disinfection Box SANITAZION BOX UVC ULTRAVIOLET UVC Box
    Yun uv lights ba same ng mga ginagamit sa bug zapper?
    Mar 2005
    #25
    parang iba wavelength nila sir.
    Quote Originally Posted by jmpet626 View Post
    Paano ko malalaman kung anong klaseng UV bulb ang pwede?
    #27
    opening the box will probably be fine in dissipating that ozone.
    huwag lang langhapin.
    #28
    UVC dapat.
    we will have to rely on the labeling, as they look all alike.
    UVC dapat.
    That's my point. Paano talaga malalaman.
    #30
    1. purchase from knowledgeable and reliable supplier, i.e., hospital equipment or laboratory equipment supplier, of good moral character. not patakbuhin nor online.
    2. befriend the manufacturer.
    good luck sa purchase nyo.
    #31
    Proper venting is also important. Baka O3 naman dumale sa yo pagtanda. I only open the box in the garage and vent it with a fan.
    Bili ka na lang ng ready made box. Yung Daimaru sa Lazada legit naman. Transparent lang yung top kaya tinatakpan ko ng black out material.
    Yung cash amoy malinis after isalang for 30 minutes. Wag lang yung mga heavily soiled.
    Has anyone bought goggles? I want antifog, silicone liner sealed ones na walang vents.
    #32
    Yung sa fly killer may violet tint pa yung bulb. The light also has a violet tint, like on those counterfeit money detectors.
    Yung UVc ay CLEAR ang bulb. The color of the light is white, like from a 7000 kelvin H.I.D. lamp.
    madami sa lazada. Yung P5k sa SM nasa 2k lang dun.
    Sterilization of stuff? Sale ang Markes sa Wilcon, 6k yung cabinet na kasya 3 cubic feet. Eto yung pang disinfect ng plates and kitchen utensils.
    #34
    Yan din sana oorderin ko kaso ayaw ni kumander ng may UVc lamp sa bahay. Takot siya baka daw may pumasok na bata sa room habang naka-On. Madali kasi makasira ng eyes ang UVc, and the damage is irreversible.
    So how do you safely and properly use yan? Iwan sa room then melrn timer paano after? Kailagan ba naka open mga windows habang ginagamit?
    #36
    google re. online fakes, folks.
    perusing, mukha ngang "meron".
    #37
    We have a UV sterilizer lamp at home. If it is being used, the area and things within its surroundings smell sterilized, like that smell when the photocopier emits its radiation on paper.
    Paano pag sa Room iniiwan naka timer then pasingawin yun room muna after matapos?
    #39
    Windows and doors closed. Position it in the room so that the rays will reach every corner. Set timer, leave the room. It will turn on, and then off, according to the timer settings. If the room has areas not in direct line of sight, reposition, repeat.
    Ilan minutes dapat pasingawin after?
UV lamps effective for COVID virus?
